How do M/T tires perform in sand? - JeepForum.com
post #1 of 17 Old 10-03-2013, 07:24 PM Thread Starter
corpulent
It seems most of the tire recommendations here are specific to mud traction. I'm in the high desert, and lucky to find a puddle.
All my off roading is in sand (sometimes incredibly fine, deep, and slick), and occasional hills with fist-sized and smaller rocks. Plus some brutally sharp sagebrush.
Whaddya think? A/T? M/T? Kevlar-impregnated spider-silk tungsten-knobbed paddles? Kidding, of course, but any recommendations for a good sand/street tire?
Thanks
corpulent is offline
post #2 of 17 Old 10-03-2013, 07:31 PM
braddf
M/T is the opposite of what you want. They are designed to dig into the ground which isn't what you want in sand. You want to glide over it with street tires or a mild a/t.
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
post #3 of 17 Old 10-03-2013, 07:56 PM Thread Starter
corpulent
Makes sense. But the A/Ts I've had before just kinda "sink & spin" in the sand.
With a bit of speed, sure, I can glide over it. But from a stop, or climbing a hill, I need a bit more "bite," as it were.
Just a more aggressive all-terrain, then, and nothing with the Mud designation?
post #4 of 17 Old 10-03-2013, 08:08 PM
braddf
I would try to stay as mild as possible. If you must have an all terrain I have heard that BFG all terrains preform pretty well in the sand. My dad has Nexen all terrains and he drove out to the outerbanks for a week with 300 pounds of gear in the back of his tacoma and said he never had the slightest problem.
braddf is offline
post #5 of 17 Old 10-03-2013, 08:40 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
I have BFG KMs and they perform well in sand. I had treadwright guard dogs before the KMs, which are basically the Goodyear MTR tread pattern, and those performed well in sand. Some of the guys I wheel with have Duratracks and those perform well. Other guys run BFG ATs and those perform well. With sand, it has a lot more to do with your driving style than it does your tires. I used to go on the dunes with my stock Wrangler SRAs and got around just fine. Ive seen people there jumping dunes in an Eagle Talon (that was really funny to watch). I will say that the MTs dig deeper, faster and will get you down to the frame a lot faster than an AT or street tires, but the point is to not start digging in the first place. Easy on the throttle from a stop, and youll be just fine.
~James
ezflip is online now
post #6 of 17 Old 10-03-2013, 09:03 PM
gcjeeping
Air down... Foot print is a big part of being successful in the sand.
_____________
gcjeeping is offline
post #7 of 17 Old 10-03-2013, 09:49 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Yes, this will help more than anything.
~James
post #8 of 17 Old 10-04-2013, 11:26 AM
C101Commando
This is the right answer... Couple that with momentum and don't stop unless pointed downhill and you'll have a great time!!
03 WJ, 4.7 Limited
C101Commando is offline
post #9 of 17 Old 10-04-2013, 01:04 PM
Cirruslydakota
Best tires to use on sand are usually worn street tires. You don't want to use M/T since they're designed to dig and will sink you fast with too much throttle. I'm leaving for obx tomorrow and where my house is requires the use of my Jeep. I'm running kumho A/T and airing them down to 13-15 psi. Last time I went I had michilen mtx4 tires and they did pretty good so I'm curious to see how the kumhos perform. Also carry an air compressor and foldable shovels.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is online now
post #10 of 17 Old 10-04-2013, 03:41 PM
jserna
1987 YJ Wrangler
AT's and air down!!
jserna is offline
post #11 of 17 Old 10-04-2013, 04:24 PM
JeepNowski
I live in very similar sand...Sugar sand we call it. My experience basically what everyone else has said. Mudders in sand are a no-go, period. I've used the BFG ATs and they work pretty good in the sand, but they'll still dig in. However, I had those BFGs in my work truck and I can tell you I never got stuck in the sand BECAUSE of the tires. Usually it was because I was too lazy to walk somewhere and decided to go for broke and go somewhere I shouldn't have gone.
JeepNowski is offline
post #12 of 17 Old 10-04-2013, 05:36 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Mts are not a "no go" by any means. I love mine in sand. Sure, if you mash the gas in 2wd, they will dig, but if you don't drive like an idiot, they are awesome on sand.
~James
post #13 of 17 Old 10-05-2013, 10:11 AM
SteelBlue_WJ
SteelBlue_WJ's Avatar
My BFG M/T Km's do very good in the sandy washes here, even very well in my old 2wd cherokee. whether the most expensive tire specifically made for sand or a run of the mill AT or MT, it wont do anything for you if you arent driving right in sand.
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline
post #14 of 17 Old 10-05-2013, 01:11 PM
dcorn
Been to the outer banks tons of times with MT's and when aired down to 15-18 psi, I haven't had a single problem. Originally had Kumho KL78's and then Goodyear MTR-K's. Even pulling out stuck vehicles in very soft sand, they spin and dig but eventually grip and go.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #15 of 17 Old 10-05-2013, 02:06 PM
skain8
skain8's Avatar
MTs are fine. Learn to drive.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is online now
