How do i shift select-a-trac the proper way? - JeepForum.com
post #1 of 20 Old 08-10-2011, 09:35 PM Thread Starter
KrazyTaxiCabbie
I bought a used 99 Laredo and i dont have the owners manual. I don't want to screw it up. Does it have to be running or turned off. Can it be moving when i shift? I just don't know the proper way shifting from 4 to 2 wheel dr. and vice versa.
KrazyTaxiCabbie is offline
post #2 of 20 Old 08-10-2011, 09:38 PM
rkperry1
01 grand cherokee selec trac here. mine gets sticky and doesnt like to shift in or out but u do it when its running thats totally fine. iv done it on the drive as well i just let off the gas otherwise it might slam into gear. iv even done it on the highway when it got a little slick i just again let off the gas for a sec till it popped in.
hope this helps
rkperry1 is offline
post #3 of 20 Old 08-10-2011, 09:39 PM
Newb1995jeepgc
1994 ZJ
aslong as your not going over 55 you can shift into 4 fulltime and part time.. but for N and 4lo you got to put the tranny in Neutral and shift it under 3MPH. Hope that helps.
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
post #4 of 20 Old 08-10-2011, 10:07 PM Thread Starter
KrazyTaxiCabbie
So it should work automatically driving 30 mph shifting from 4 to 2 with no problems? When you say it "sticks" do you mean it won't turn well and the whole vehicle kinda jumps. Because that is what happens when i shift from 4 to 2. Seems like its doesn't want to shift correctly so i'll put it back into 4. It just acts like it doesn't want to go back to 2wd.
post #5 of 20 Old 08-10-2011, 10:09 PM
Newb1995jeepgc
1994 ZJ
yes no problem.. and it sometimes will stick going from 4 to 2. It just takes alittle jerk on the shifter and it will go back.. its normal.
post #6 of 20 Old 08-10-2011, 10:52 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
If your front and rear tires are worn differently, it is very likely that the transfer case is binding and won't shift from 4HI PT to 2WD. Changing the transfer case fluid may help. The good news is that you can safely run in 4 Full Time indefinitely without trouble.
~Richard
billzcat1 is offline
post #7 of 20 Old 08-10-2011, 11:00 PM Thread Starter
KrazyTaxiCabbie
Thanks for the info all! I'll go find an empty parking and test it all out.
post #8 of 20 Old 08-10-2011, 11:05 PM
rkperry1
yeah the first time i noticed it sticking was when i got stuck in snow and shifted it and didnt let it the gas and it banged into gear hard. learned my lession. but i still have to shift the shifter back in forth to get it back in 2wd sometimes.
rkperry1 is offline
post #9 of 20 Old 08-11-2011, 06:11 AM
NeverL8
OMG that what happent to my jeep, it stuck at 4wd, what the trick u guy did to make it go back to 2wd ?
NeverL8 is offline
post #10 of 20 Old 08-11-2011, 07:59 AM
WJ04
Also No one mentioned you have to be driving straight when shifting in or out of 4wd. NEVER do it while turning because it wont engage right and cause grinding and binding. selectrac is a shift on the fly TC which means you can shift in or out of 4wd while driving under 55mph. once you shift it.. let of the gas for 2 seconds then tap the gas again let of again and you should be good to go. 4LO however you have to put the transmission in neutral while rolling no more than 3-5mph then in one sweep push down on the 4wd shifter and firmly pull it back into 4lo then put the transmission in drive and your in 4lo. same process shifting out.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #11 of 20 Old 08-11-2011, 12:35 PM
KayCeeJeep
Sometimes "popping" the gas pedal a couple times will help it drop back into 2wd or with my old one sometimes I'd simply stop and back up 20 feet or so and you could feel it drop. Never had any troubles getting them in, but they can be a little ornery to get back out.
KayCeeJeep is offline
post #12 of 20 Old 08-11-2011, 04:13 PM
tjlmbklr
I wanted to add to this thread since I too have concerns on proper shifting with my new (to me) Selec-trac. I here that Part Time 4HI is not supposed to used for regular driving with slippery conditions because of the ration split between front/rear, is this true? The reason I ask is, why would they have that first in line, why not have the Full to first then part time under that?
Just curious.
Great post, thanks for asking.
Bone Stock 2002 Grand Cherokee Limited
4.7L HO, Changed Stock NV247 Quadra-Drive T-case to a 242 Selec-Trac Shifter and all.
Upgraded my rims to 5 Spoke Rogue from '11 Grand Cherokee
tjlmbklr is offline
post #13 of 20 Old 08-11-2011, 04:41 PM
billzcat1
2003 WJ
I think it has to do with how the shift collars move within the transfer case.
~Richard
post #14 of 20 Old 08-11-2011, 05:34 PM
tjlmbklr
Sure...take Jeeps side!
tjlmbklr is offline
post #15 of 20 Old 08-11-2011, 07:33 PM
rkperry1
when mine gets stuck i run the shifter back and forth fron 4wd to 2wd and sometimes whift to park or N that seems to help but yah keep ramming back to 2wd haha. i usually cant tell if its in 4wd till it gripps the pament durring turns or the roar of the front end during driving
rkperry1 is offline
04 WJ quadra trac to selec trac shifting points icecool742 WJ Grand Cherokee Forum 0 07-02-2011 12:04 PM
OCD Select Trac question Dissenter WJ Grand Cherokee Forum 11 01-02-2011 09:08 AM
2000 Jeep Grand Cherokee Laredo Select trac I 6 Battery Cable Terminal Problem chesapeake WJ Grand Cherokee Forum 1 11-06-2010 06:27 AM
Quadra-trac to selec trac swap linkage problem threezjs WJ Grand Cherokee Forum 13 04-29-2010 10:32 PM
RB1 NAV Select Encoder Button - joystick cincyjeeprs WJ Grand Cherokee Forum 3 03-22-2010 12:14 PM
