How do i remove the clutch fan from the water pump? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > How do i remove the clutch fan from the water pump?
TJ Dana 60 - BOLT IN REARRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge Bushings
Unread 11-16-2011, 06:04 PM   #1
jeep3000gt
1994 XJ Cherokee
Ok I can't seem to remove the clutch fan from the water pump pully. Do u have to hold the pully while turning the fan?
This is on the 4.0. Also what size wrench fits that nut? And if I have I hold the pully what tool do I need?
jeep3000gt is offline   Reply With Quote
Unread 11-16-2011, 07:04 PM   #2
Cirruslydakota
Yikes, I can't quite remember the size off the top of my head. I want to say its 1 5/16" ill have to go look in my toolbox to be sure. Anyway, if you have access to a air hammer it'll make this job a snap. If not you'll need a wrench and a good hammer and patience.
Bear - 1999 Jeep Grand Cherokee Laredo - 250,000 Miles, BDS 2" lift, Overland rock rails, Dynomax cat back exhaust, 245/75/16 Kumho KL78's, Rebuilt 4.0 @ 244,000 miles.
Apollo - 2008 Mazdaspeed3
Velvet - 2005 Ford Focus ST - Wifes ride
Cirruslydakota is offline   Reply With Quote
Unread 11-16-2011, 07:25 PM   #3
Sohcvtec1995
you might want to go rent a fan clutch removal kit.has 2 wrenches one to hold the clutch/fan in place, the other to get the nut off.
Sohcvtec1995 is offline   Reply With Quote
Unread 11-17-2011, 08:09 PM   #4
jeep3000gt
1994 XJ Cherokee
Where could I rent a. Kit like that?
Unread 11-17-2011, 09:17 PM   #5
drrm123
1994 ZJ
A couple of options would be a strap wrench from sears to put around the pulley and use a adjustable wrench on the nut, or get some flat stock of metal and make a half arc drill two holes with same spacing as bolts on pulley. Make handle about 1 1/2 ft to 2ft long. http://www.sears.com/craftsman-2-pc-...p-00945570000P
2001 Jeep Grand Cherokee Laredo 6 cylinder Selectrac
$2400 installed new radiator 1 window regulator 2 oxygen sensors
drrm123 is offline   Reply With Quote
Unread 11-17-2011, 09:21 PM   #6
Sohcvtec1995
local parts stores
Unread 11-29-2011, 12:06 PM   #7
specia1k
I believe if you leave the serpentine belt on, place an adjustable wrench on the fan nut and tap/bang counter clock wise, it will release. I saw a video for replacing a water pump and thet's what they did.
2004 Jeep Grand Cherokee Limited 2x4 4.0L
2002 Jeep Grand Cherokee Sport 2x4 4.0L
1998 Jeep Grand Cherokee Laredo 2x4 4.0L
"Three daughters, three Jeeps"
specia1k is offline   Reply With Quote
Unread 11-29-2011, 02:25 PM   #8
1AAdam
X2 i am pretty sure that's how it would come off. that's how i have replaced them in other vehicles. the pulley may still slip with the belt on it esp if u hammer it but it would prob stay put for u.
Adam
1aauto.com
888-844-3393
1AAdam is offline   Reply With Quote
Unread 11-29-2011, 03:13 PM   #9
JJCJeep
when I did my water pump I just jammed an old screwdriver into one of the small holes on the pulley to hold it still and wacked the wrench holding the nut with a big *** hammer and it broke free. I figured I was replacing the pump anyway so i wasn't worried about damaging the pulley. Prob not the most conventional way but it was quick and it worked.
JJCJeep is offline   Reply With Quote
Unread 11-30-2011, 01:29 PM   #10
jeep3000gt
1994 XJ Cherokee
I'm replacing the fan clutch and the water pump. I read somewhere that I have to remove the radiator and Trans cooler lines to do this? I have the 4.0 i6
Unread 11-30-2011, 10:12 PM   #11
jeep3000gt
1994 XJ Cherokee
Okay I got the clutch fan wrench but i can't seem to get the bolt off. Do u put the wrench on the bolt and turn it counter clockwise if your facing the jeep? Do I also need a tool to hold the water pump pully?
