How do I identify if a 4.7 is HO or not? - JeepForum.com
post #1 of 3 Old 06-11-2012, 06:13 PM Thread Starter
Gru
2003 WJ
I am likely going to have an extended warranty replace the engine in my 03 Overland. Just to make sure everything is as it should be, I am wondering how I would tell a 4.7 HO from a non HO.
Also, if this is coming from a wrecked Jeep, is there a certain vintage 4.7 HO I should avoid? For example; anything pre 2001? Considering they are probably going to go by mileage, is there a later year that might be better than a 2003? I would assume not because 2005 was the Hemi, right?
I suppose I am looking for something like a block stamp.
Gru is offline
post #2 of 3 Old 06-11-2012, 06:21 PM
narnwv
narnwv's Avatar
If they don't use an HO engine, they'll have to swap wiring harnesses and PCMs, as the standard 4.7 doesn't have the 2 knock sensors.
To triple check, there will be "H.O." in the casting of the heads.
H.O. 4.7 didn't appear until 2002, and wasn't put in anything beyond the 2004 WJ to my knowledge. There were updates to the 4.7 for the WK (2005+), but no H.O. engine.
~Aaron
narnwv is offline
post #3 of 3 Old 06-11-2012, 06:32 PM Thread Starter
Gru
2003 WJ
Perfect!
Just what I was looking for.
Thank you narnwv.
Gru is offline
H.O. Cams-How to identify narnwv WJ Grand Cherokee Forum 8 03-12-2012 03:21 PM
Identify this part... JeepIt WJ Grand Cherokee Forum 5 03-02-2012 01:09 PM
Wj Fan Relay: Identify Wires dmextreme77 WJ Grand Cherokee Forum 2 09-07-2011 07:13 PM
Identify this bolt? worldlysaint WJ Grand Cherokee Forum 8 06-20-2011 12:55 AM
Identify this lift please finrisk WJ Grand Cherokee Forum 32 10-07-2010 06:48 AM
