How to delete fault codes on 04 Grand Cherokee??? - JeepForum.com
post #1 of 17 Old 12-28-2011, 06:19 AM Thread Starter
alfaitalia
Wj How to delete fault codes on 04 Grand Cherokee???
Does anyone know how, or is it even possible to, delete fault codes on a 04 Grand Cherokee (CRD if that makes any difference - I dont think it does), without buying a reader (ive got one but it does not want to talk to my jeep!
Ive recently had probs (see recent posts) but now the probs are solved I want to delete the fault codes as well. I know they will go after 40 cold start cycles (as long as faults dont reappear) but thats about a month for me!
Any ideas?................... and before anyone says "Disconnect the battery!" that does not work on 04 models. Have tried it on mine and two others from between 30 seconds to 24 hours and codes remain!!
Looking forward to your replies.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #2 of 17 Old 12-28-2011, 06:56 AM
BandGauto
Go to Auto Zone they will do it for free.
BandGauto is offline
post #3 of 17 Old 12-28-2011, 06:56 AM
BigBeefy
I have an 04 and it worked for me. (disconnecting battery)
2004 Overland, 75k miles, 4.7L H.O.
1997 ZJ TSi, 265k miles, 4.0 I6
BigBeefy is offline
post #4 of 17 Old 12-28-2011, 06:58 AM
BandGauto
OOPS sorry I just noticed you were in Great Britain.
post #5 of 17 Old 12-28-2011, 07:00 AM
BigBeefy
Must be an export model thing that is keeping the light on.
Disconnect batt and the computer.
Best I can do other than suggesting to take it to a dealer and have it done from them.
BigBeefy is offline
post #6 of 17 Old 12-28-2011, 07:30 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Disconnecting the battery will work as long as the problems are actually fixed. Otherwise, I am sure there are autoparts stores in Great Britain who can do it for you, but again, if the battery disconnect doesn't work, clearing them with a code reader isn't going to work either....
~James
ezflip is online now
post #7 of 17 Old 12-28-2011, 09:44 AM
1AAdam
CRD!!
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #8 of 17 Old 12-28-2011, 09:45 AM Thread Starter
alfaitalia
If you dont know dont guess . It helps no one. Many cars I have had in the past could only be reset with a code reader rather than battery disconnect whether the probs were fixed or not. The idea is to stop regular Joes doing it and make them go to there dealers I would think. Just thought someone on here might know a trick.
post #9 of 17 Old 12-28-2011, 10:22 AM
MadderThanMax
^ I have to agree with there on that one mate, the disconnect thing doesn't work! It may do for the American but not over here in Blighty, tried it numerous times without result even left it over night and guess what.. it doesn't work!
With regards the Autoparts Stores no there ain't.. most of our "shops" buy the aftermarket readers like the Sun Diagnostics or Snapon Diagnostics very few will invest in Chrysler/Jeep equipment probably because its not a premium selling vehicle over here unlike BMW/Mercedes/VW/Audi/Ford.
Sorry for dispelling the rumour.... :-(
MadderThanMax is offline
post #10 of 17 Old 12-28-2011, 11:52 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
I wasn't guessing. I have never heard of the battery disconnect not working for jeeps. Whether it be American or otherwise. If the problem is actually fixed, it will work. If it doesn't work, the underlying problem is not fixed. There have been several hundred upon several hundred threads on this forum in my 3+ years of membership discussing this very issue. Do a search, Im sure you will find some.
~James
post #11 of 17 Old 12-28-2011, 11:57 AM
MONSooNmonkey
Disconnect battery, tap the brake pedal with the key rolled forward and it should 'kill' the remaining power.
Sadface :(
MONSooNmonkey is offline
post #12 of 17 Old 12-28-2011, 03:37 PM Thread Starter
alfaitalia
No, does not work on 2004 UK spec Jeeps. Even tried leaving the headlight switch in the on position to make sure there was a high current drain..
And the reason is...............well I spoke to Jeep today (this is Jeep UK dont forget my American friends!!) and they told me the fault code memory does not rely on power (12volt) for its fault code memory so disconnecting the battery will not erase the codes no matter how long you disconnect the battery. You would physically have to de solder the memory chip from the curcuit board and short it to forget the codes. So there you have it...you either use a reader or wait for 40 code starts to erase the codes automatically.
Also dont forget that this is a Mercedes engine/transmission and ive yet to come across a german car that can have its fault codes deleted by battery disconnection although there will be a few older ones. I worked for a German car dealership for 14 years so I saw a few!!
post #13 of 17 Old 12-28-2011, 04:37 PM
BigBeefy
Leave it to the Germans to turn something easy into a difficult task.
BigBeefy is offline
post #14 of 17 Old 12-28-2011, 06:03 PM
eogg
False. The WJ was designed before the merger. Production started 10 weeks after the merger. It is possible that some of the electronics were updated by Daimler.
Edit: The merger was announced in May and was official in November. The WJ had already been on sale for two months by then.
Constantly emptying every pocket
Colorado Jeep Club Member #1010
eogg is offline
post #15 of 17 Old 12-29-2011, 08:29 AM
FrankU
Love those CRD's ! We have a fleet of the 3.6 CRD's in the Sprinter van's. Most are turning 300k miles with minor repairs and excellent fuel mileage. And they move out too.
FrankU is offline
2000 grand cherokee random codes. crazyman03 WJ Grand Cherokee Forum 2 07-22-2011 12:03 PM
Fault codes RedHot-30 WJ Grand Cherokee Forum 4 05-27-2011 01:54 AM
My 1999 Grand Cherokee keeps stalling - No Codes though Boundries WJ Grand Cherokee Forum 5 08-14-2010 11:55 AM
How to pull codes from 2000 Jeep Grand Cherokee drrm123 WJ Grand Cherokee Forum 3 07-26-2010 05:54 PM
03 Grand Cherokee codes budro69 WJ Grand Cherokee Forum 2 05-13-2010 03:59 PM
