How to change power steering fluid??? - Page 2 - JeepForum.com
post #16 of 33 Old 06-29-2011, 05:46 AM
Apollo21
subscribed
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #17 of 33 Old 06-29-2011, 06:09 AM
threeb
Originally Posted by Thomahawk
Sorry i am not familiar to terms like subscribed and opcorn. I am VERY stupid on These things, PLS explain.
They are watching the thread, much like a movie.
Pulled that one out of my ***.
LJ Owners Group member #431.
threeb is offline
post #18 of 33 Old 06-29-2011, 07:04 AM
txtumbleweed
Sure About That?
Originally Posted by WiCkeDuDe View Post
He doesnt have the hydraulic fan. Plain power steering fluid is fine.
http://wjjeeps.com/tsb/tsb_wj_1900503.pdf
Check out the TSB - there are different power steering fluids in play for different years of WJs. The OP needs the MS 5931 spec'd fluid which isn't necessarily "plain power steering fluid". The picture of the MOPAR power steering is the correct version for his 20000 WJ.
Y2K WJ 4.7
txtumbleweed is offline
post #19 of 33 Old 06-29-2011, 08:39 AM Thread Starter
Thomahawk
Changed it today, found it hard to diconnect Return hose and put on a cap.
Used a pump to pull out of the tank, refilled it with fresh power steering fluid, started her up turned steering wheel left right 3-4 times,
Then i pulled out fluid and refilled, repeated this 3 times.
I got out and refilled 1QT.
Buildthread
Thomahawk is offline
post #20 of 33 Old 06-29-2011, 08:45 AM
WiCkeDuDe
WiCkeDuDe's Avatar
He doesnt have the hydraulic fan and doesnt need the MS5931, which is actually the mopar version of plain power steering fluid. If you read the bottle alot of the newer generic fluids meet the 5931 spec anyways. So in all alot of hype about nothing. Half the dealerships will purposely put in ATF4 anyways.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #21 of 33 Old 06-30-2011, 05:58 AM
kentman
kentman's Avatar
2006 XK Commander
This is what the factory service manual for the '02 WJ for the 4.7L says.
"CAUTION: Use MOPAR Power Steering Fluid or equivalent. Do not use automatic transmission fluid and do not overfill."
The "or equivalent" to me says that the MOPAR fluid is not a special blend or unique. I expect that any modern power steering fluid would be adequate.
I recently replaced the hydraulic fan, and I did not use MOPAR fluid. I have seen no issue relative to the new non-MOPAR fluid. In fact, the fan died when it had only seen MOPAR fluids. Lot of good that fluid did for me.
I am not a big fan of the hydraulic fan. Too complex and expensive for the purpose if you ask me. I like the KISS principle, keep it simple stupid.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #22 of 33 Old 06-30-2011, 08:49 AM
txtumbleweed
It really isn't that easy to find a brake fluid that is MS5931 compatible - most brands don't list compliance with the MS5931 standard. I suspect there is a reason why MOPAR specified a standard and it doesn't really have anything to do with the hydraulic cooling system since MS5931 was specified for WJs 3years before the hydraulic cooling system was even introduced.
What is your source that says MS 5931 = "plain power steering fluid"?
Y2K WJ 4.7
post #23 of 33 Old 07-08-2011, 06:10 AM
kentman
kentman's Avatar
2006 XK Commander
He was probably getting his data from the following location.
WJ Jeeps - Power Steering Fluid - Other
It says "no exceptions" which is bogus if you ask me. The factory service manual does not say that, and that is written by Chrysler.
Thus, you need to take WJ Jeeps with a grain of salt. It is good information, but it may lead you astray once in a while.
kentman is offline
post #24 of 33 Old 08-15-2012, 07:41 AM
botakbeng
Thought this might help...
https://partimages.genpt.com/partimages/1427004.pdf
Valvoline Power Steering Fluid
Part#VAL 602241
Project "Hippo"...http://www.cherokeeforum.com/f46/project-hippo-black-99-xj-128806/
botakbeng is offline
post #25 of 33 Old 08-15-2012, 09:47 AM
hamilton5
over a year later... yeah maybe
hamilton5 is offline
post #26 of 33 Old 08-24-2012, 10:47 AM
The_Scout
It helps me at least.
Leave no trace.
The_Scout is offline
post #27 of 33 Old 08-24-2012, 02:54 PM Thread Starter
Thomahawk
Niiiiceeeeee!
Buildthread
post #28 of 33 Old 08-24-2012, 04:10 PM
funkduck
2015 KL Cherokee
Ditto, I see nothing wrong with resurrecting an old thread if there's new data to add
funkduck is offline
post #29 of 33 Old 07-16-2013, 09:51 AM
Svensson
Im gonna do this asap!! I have the hydralic system, the fan does not speed up, steering is slow aaaand the PS fluid is red/brown. I have cycled through on bottle of ps fluid, but its still not right color.
Reviving thread once more.. Zombie thread
2004 WJ 2,7 CRD.
2" OME lift, rear addco swaybar, 17" Ion Alloy 171 w/33/12,5x17 Baja MTZ's, 2 din bezel, 30" led lightbar, JKS adjustable trackbar, Rancho SS, Bullbar, Projector Headlights, front Carolina Drivline. Bilstein shocks for 4" lift, 2"BB, IRO front UCA.
Build Thread's:
Norwegian site:
Jeepforum Picture/Buildthread:
Svensson is offline
post #30 of 33 Old 07-16-2013, 10:02 AM
WiCkeDuDe
WiCkeDuDe's Avatar
A lot of power steering fluids have a red tint to them these days so being red isn't a huge red flag. I've actually started using the royal purple steering fluid in my wj and its worked much much better than the mopar stuff....
