How to change power steering fluid??? - JeepForum.com
post #1 of 33 Old 06-28-2011, 01:12 PM Thread Starter
Thomahawk
Hi guys,
I am going to change power steering fluid, i know i have to:
Get both My front wheels off ground.
Suck out fluid off power steering resorvoar, refill with new fresh fluid.
Disconnect Return hose.
Turn wheels with steering wheel from left to right and so on.
Make sure resorvoar is not going Low on fluid, add all the time.
Keep on like this until only fresh fluid comes out of Return hose.
Right?
Also i need to know Where is the place to disconnect the Return hose? which hose is it?
All help apriciated, Thanks, Thomas.
Buildthread
Thomahawk is offline
post #2 of 33 Old 06-28-2011, 02:10 PM
WiCkeDuDe
WiCkeDuDe's Avatar
I pull the return hose at the tank, install a cap on the tank and then put the return hose in a bottle. Start it up, flush, put more fluid in, flush, etc.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #3 of 33 Old 06-28-2011, 02:49 PM Thread Starter
Thomahawk
Thanks man. But which one is the Return hose? The one That connect at the bottom of tank?
Do i have to lift the front tires off ground or can do it on ground?
Buildthread
post #4 of 33 Old 06-28-2011, 02:52 PM
1AAdam
subscribed!
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #5 of 33 Old 06-28-2011, 03:09 PM Thread Starter
Thomahawk
Sorry i am not familiar to terms like subscribed and opcorn. I am VERY stupid on These things, PLS explain.
Buildthread
post #6 of 33 Old 06-28-2011, 03:14 PM
WiCkeDuDe
WiCkeDuDe's Avatar
So mine are both 2002s so they have the *&#^*^%*@^%@ hydraulic fan and 2 returns. The return for you should still be the one on the back and bottom of the PS tank, right above the drive exhaust manifold. Unattach this and stick it in a bottle, but you must cap the tank or your new fluid will run right out. I dont lift the tire off the ground for flushing. Since it pushes the fluid straight out the wheels wont turn anyways. But if you do lift it off the ground and turn the wheels it could flush the gear a bit more, and will help with bleeding the system later. Your choice.
post #7 of 33 Old 06-28-2011, 03:17 PM Thread Starter
Thomahawk
THANKS MAN! Apriciated, i Will do it tommorow. 
Buildthread
post #8 of 33 Old 06-28-2011, 03:17 PM
Son-of-Beast
Be sure and only use the approved fluid, no generic fluids - I had a mechanic darn near ruin my hydraulic system by using regualr brake/PS fluid - the 4.7 has a 3-spd hydraulic fan that needs a lot of pressure - mixed fluids are bad, the fan won't run, and the engine will overheat.
I went out and got a quart of the stuff from the Stealership, think it was like $16-18 if I remember - cheap insurance.
It is a result of the relationship with Daimler, great German engineering but very specific tolerances and specifications - same thing for the Quadradrive axles and the need for a friction modifier. Dont cheap out on the fluids.
'Son-of-Beast' - '02 WJ Limited, 4.7, 545RFE 5-spd Auto, Quadra-Drive, KOR 2.5" BB, Rancho RS5000's, Firestone Destination AT 265/70R17's, Flowmaster DeltaFlow 40, KMA/TAG armor, JK Fuel Door, Spyder CCFL Halo Projectors, LED Taillights, LED Interior Lights - Build Thread:
Son-of-Beast is offline
post #9 of 33 Old 06-28-2011, 03:23 PM Thread Starter
Thomahawk
What??? Cant i just use water???
Jkd, bought the mopar steering fluid for 10$ of ebay.
Also bought this.
Buildthread
post #10 of 33 Old 06-28-2011, 04:11 PM
WiCkeDuDe
WiCkeDuDe's Avatar
He doesnt have the hydraulic fan. Plain power steering fluid is fine.
post #11 of 33 Old 06-28-2011, 04:23 PM
Son-of-Beast
You are correct, it was introduced in '01 - I still say don't cheap out on fluids but if he doesn't have the hydro fan the fluid issue may be less important.
post #12 of 33 Old 06-28-2011, 07:33 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Yeah I hear you.
post #13 of 33 Old 06-28-2011, 07:42 PM
xJoshxx
2012 WK
i used a vet/dry vacuum with a small hose on it cycled through 1 quart of new Mopar fluid. for 2 days sucked it all out refilled.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #14 of 33 Old 06-28-2011, 08:56 PM
86cj74.2L
86cj74.2L's Avatar
[QUOTE=xJoshxx;11780581]i used a vet/dry vacuum with a small hose on it cycled through 1 quart of new Mopar fluid. for 2 days sucked it all out refilled.[/QUOTE/]
+1
I used a turkey baster to suck it out. Since I have the hyd setup and it's always circulating I just did it a few times then did it a few more times a few days later
86cj74.2L is offline
post #15 of 33 Old 06-29-2011, 05:03 AM
pdpunome
x2 i have 5 turkey baisters in my box at all times go to the dollar store and grab a couple always nice to have for power steering, brake, and coolant fluids.
pdpunome is offline
