-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   how to bleed and maybe flush brakes (http://www.jeepforum.com/forum/f310/how-bleed-maybe-flush-brakes-2196841/)
mustang67ford 03-09-2014 11:12 AM
I am doing the brake caliper swap to the front of a 99GC. I need some help on how to bleed the brakes once the new calipers are on. I don't know yet if I will just bleed the brakes or flush the whole system with new fluid. I purchased a 1-man brake bleeder kit because I will be by myself. It is a little bottle with a hose from advance auto.
Any how-to help would be great, thanks.
Drek 03-09-2014 12:15 PM
Check out this video:
doityourselfMM 03-09-2014 12:26 PM
The video is good, but I do my brakes a bit differently.
Some basics .....
Flush the entire system. Start with the RR, LR, RF, and Left Front. Always work first with the caliper farthest from the Master Cylinder, Fluid Reservoir. Don't cheap out with new brake fluid. One quart should do it, but have a second on hand, just in case.
I always use a 'turkey baster' to suck out all of the old fluid from the reservoir first. That way, you don't have to bleed it through the lines to get to the new fluid. Of course, with the old fluid out, top off the reservoir with new DOT 4. I use ATE fluid myself. It comes in both blue and yellow tints. I alternate colors each fluid flush. It is easy to see the new fluid come thru, as it is a completely different color from the old.
And whatever you do, do not let the reservoir run dry, or you will have to start the process all over agin.
mustang67ford 03-09-2014 02:23 PM
ok, so when I put the new front calipers on, do I manually try to put fluid in them before connecting the line and do I need to worry about air in the caliper getting up into the brake line someplace? I could pump the back a few times and it be fine, but unknowingly, an air bubble is in the middle of the line to the back someplace.
Do I change the front calipers before trying to change the fluid?
Doing the order noted above, how do I know when I have new fluid at the caliper, just by trying to judge the color? Since I'll be doing it by myself, about how many pumps of the pedal will it take to the rear?
Thant was a helpful video, but I should be able to bleed the rear without taking the tires off. My one tire is actually stuck on for some reason. Even loostened the lug nuts and lowered the vehicle but it still didn't pop loose.
slicklizzard 03-09-2014 04:18 PM
Yes, you'll know you have new fluid at the caliper by watching the color. Even in the dark with a flashlight, it was easy for me to see when mine changed from that nasty brown honey color to the new color.
kmcnulty79 03-09-2014 06:07 PM
You can use dot 4 in WJ? I thought dot 3 only or you will ruin your brake lines?
mustang67ford 03-09-2014 06:08 PM
I liked the bottle idea in the video. I returned the one from advance auto and will make a similar one. Do I need to put new fluid in the bottle or use what I take out with the turkey baster?
Drek 03-09-2014 06:09 PM
I know the "Valvoline DOT 3 and 4" fluid is OK to use in the WJ's.
kmcnulty79 03-09-2014 06:13 PM
Good to know
grussell 03-09-2014 06:31 PM
Since you will have all new fluid in the front, go ahead and flush the rears too. No way to tell you how many pumps, just depends on how much air is in the system. You can use the old fluid in the bottle. The purpose of the bottle is to keep air from going back in the caliper since you don't have a helper to tighten the bleed screw before your let off of the brake pedal.
Another warning-if the brake fluid gets on anything painted it will remove the paint.
pinky2252s 03-09-2014 06:39 PM
DOT 3, 4 and 5.1 are all technically fine.
mustang67ford 03-10-2014 10:56 AM
So what is the order? Connect front calipers, bleed rear, then move to the front where there is no fluid in the calipers yet?
Or do I start with the front by bleeding them both til the old fluid comes out then remove fluid from the reservoir, add good fluid, then move from the rear to the front til I see good fluid?
86cj74.2L 03-10-2014 01:59 PM
Keeping the resivour full I remove the brake hose and let it drip.
Then remove the caliper assembly.
When putting on the new caliper on I open the bleeder so the fluid has a place to go and then I install the brake hose on the caliper. By the time I get brake banjo bolt tight brake fluid is comming out the bleeder screw.
That way there isn't a way for air to enter the system and float around. What little air is in the system stays in the caliper till you pressure bleed it.
mustang67ford 03-10-2014 03:37 PM
I'm thinking of flushing the system before changing calipers so no old fluid gets into the new calipers.
Drek 03-10-2014 05:34 PM
No need to. Just replace your calipers and then flush the whole system.
The time now is 12:49 AM.
