Hitch mounts that fit the WJ - JeepForum.com
post #1 of 4 Old 06-03-2014, 12:01 AM Thread Starter
snoWJ
Looking for some quick info...anyone know if any other models have OEM hitches that will fit on the WJ? Thanks.
1999 WJ 4.0L Selec-Trac~ 2.5" OME coils + 3/4 Front Spacer\\Bilstein 5100s\\245-75-16 Bridgestone Blizzak DM-V1\\Zone Extended Rear Links
snoWJ is offline
post #2 of 4 Old 06-03-2014, 11:56 PM
andrewx12
I just put a Reese hitch on mine. Product # 33018. Turned out pretty good to me. Fits behind the bumper and fills in the bumper trim thingy if you have it. Very solid, although I haven't gotten a chance to test it yet.
Found it on craigslist for $50. $10-15 in hardware and it was bolted up, no drilling needed. You will want grade 8 bolts or better. Otherwise I don't think any other models have the same holes for the frame as ours. You could always drill new ones but it's not really a great idea.
Current repairs needed:
AT filter and fluid
andrewx12 is offline
post #3 of 4 Old 06-04-2014, 03:08 AM
losttech
losttech's Avatar
Reese is the only one that's close to OEM.
You can get under the tank hitches if you want and if you order from the dealer all they sell is the under the tank ones now not through the bumper they no longer make it for the WJ.
losttech is offline
post #4 of 4 Old 06-04-2014, 03:55 AM
CHULOGORDO82
2015 WK
I have the reese hitch and it's awesome
Sent from 36000ft crusing at .84Mach using ACARS
CHULOGORDO82 is offline
