Hitch mounted tyre (tire!) carrier question. - JeepForum.com
post #1 of 15 Old 07-20-2014, 07:14 AM Thread Starter
alfaitalia
Nearly finished now,,,,I know, I know its been months but time is always a rare commodity to me!
Ive designed it to be close to the rear hatch for cosmetic/departure angle reasons and its all pretty solid. Its only about 1/2 an inch away from the trim piece with the rear window switch in. Although its solid I can push it hard enough (with tyre on) to touch the paint on the trim.....so I guess when Im hitting bumps on the road (especially off road) there is a chance it may contact. Its got a rubber protector to stop paint damage but I would like to add some sort of retainer it the top (somewhere around wiper of glass switch height) to prevent the possibilty of forward/backward movement. This should make it overall more solid as a bonus.
There are lots of quick release catches around that will do the job but how do I mount it to the hatch. Two ways seem to be obvious (something that goes under the window ruber and spreads the load along the inside edge or perhaps something that bolts on with the fixings hidden under the handle trim ....more difficult but possible). Strength concerns me a bit at I dont want to hit a large hole and have the weight of the carrier/tyre tear a chunk out of my rear hatch!!! So have you guys got a better idea (perhaps one you have used yourself) or better still if you have fitted a stabilising mount of your rear mounted tyre carrier and can post pics.
Look forward to your ideas/solutions.....
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #2 of 15 Old 07-20-2014, 08:32 AM
veiri86
2003 WJ
Subscribed; as am in the same boat as of today because my 33" tire is taking all the space in the cargo area. I was thinking of the same thing and came to my mind to do tringular shaped carrier. I will post a photo of the drawing when am back home from work
Sent from ME
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #3 of 15 Old 07-20-2014, 08:37 AM
WJ297
Can you post a picture of the carrier?
WJ297 is offline
post #4 of 15 Old 07-20-2014, 08:55 AM
veiri86
2003 WJ
It is something like this but the tow hitch will be in the middle and the tire will be as low as possibe
R.I.P ratmonkey
Build thread:
veiri86 is offline
post #5 of 15 Old 07-21-2014, 04:10 AM Thread Starter
alfaitalia
Thats not too dissimilar to mine.....how is it prevented from rocking back and forth when under load ....like off road?
post #6 of 15 Old 07-21-2014, 10:48 AM
veiri86
2003 WJ
This photo i found online, can be a good idea, with two additional diagonal rods on both sides, one end of the rods on the vertical bar and the other end on the horizontal bar connected to the tow hitch.
Sent from ME
R.I.P ratmonkey
Build thread:
veiri86 is offline
post #7 of 15 Old 07-21-2014, 11:32 AM Thread Starter
alfaitalia
Mine already had that but there is still a certain amount of flex and movement on the joints and mounts so I think some sort of catch at the top will be the only way to make it rock solid. Don't forget that mine is a swing out hitch mounted carrier...so more moving parts.
Sent from the Dark Side using only the Force.
post #8 of 15 Old 07-21-2014, 12:01 PM
veiri86
2003 WJ
If you don't mind can you please share some photos if they are available
Sent from ME
R.I.P ratmonkey
Build thread:
veiri86 is offline
post #9 of 15 Old 07-22-2014, 03:23 AM Thread Starter
alfaitalia
My (poor quality phone) pics follow!! Sorry about the ones on the Jeep being nearly in the dark! There has been more bracing welded on since then (pics about a month old) but it gives you an idea. Dont forget that UK hitches are very different to US ones making it easy to use a bolt on plate.
Click image for larger version
post #10 of 15 Old 07-10-2015, 03:11 PM
BlueJc
That looks fantastic. Does this do anything/change you insurance premium? I wouldn't mind making one.
2002 2.7 CRD Jeep Grand Cherokee. 205 BHP, 500 NM of torque, Bluespark Automotive Pro Tuning.
BlueJc is offline
post #11 of 15 Old 07-10-2015, 05:17 PM Thread Starter
alfaitalia
Erm.....it's not on at the moment (still trying to stop the back and forth movement when off road)......but I may have forgotten to mention it to the insurance company! To be honest it does not increase performance or decrease safety so I should not think they would care. They charged no extra for my lift....and that could affect both.
Sent from the Dark Side (of the Pond) using only the Force.
post #12 of 15 Old 07-10-2015, 05:34 PM
wjjeep19
Originally Posted by alfaitalia
Erm.....it's not on at the moment (still trying to stop the back and forth movement when off road)......but I may have forgotten to mention it to the insurance company! To be honest it does not increase performance or decrease safety so I should not think they would care. They charged no extra for my lift....and that could affect both. Sent from the Dark Side (of the Pond) using only the Force.
Are you going to get a tire cover for it? Any worries about it rusting or dry-rotting etc?
Sent from my iPhone using C, C++, Objective-C, and Swift
2002 4.Slow
2.5" lift
Software Engineer
wjjeep19 is offline
post #13 of 15 Old 07-10-2015, 05:58 PM
derekmac
I need something like that! With tools, recovery gear, and a 32 in the back, it doesn't leave me with much room. alfaitalia, can you still use your hitch as a recovery point?
2005 TJ Rubicon
derekmac is offline
post #14 of 15 Old 07-11-2015, 03:08 AM Thread Starter
alfaitalia
I have got a cover.....but it looks much better without! I rotate my wheels every three thousand miles or so to keep the wear even so I don't think UV damage with be an issue.....especially with our 4 sunny days a year!
post #15 of 15 Old 07-11-2015, 03:09 AM Thread Starter
alfaitalia
Yes....I work at a caravan dealer so being able to tow/recover was very important.
