High idling upon start up! - JeepForum.com
post #1 of 9 Old 09-22-2013, 11:14 PM Thread Starter
haddadin23
I have a 02 jeep grand cherokee Laredo. When starting up car runs at about 1800rpms after a few minutes goes down to about 1400. Then runs between 700 and 1000. Any suggestions? Thank you in advance!
haddadin23 is offline
post #2 of 9 Old 09-22-2013, 11:15 PM
bradywgn71
bradywgn71's Avatar
Clean your Idle Air Control valve on the throttle body.
http://www.wjjeeps.com/service/tbody.htm
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #3 of 9 Old 09-22-2013, 11:22 PM Thread Starter
haddadin23
I'm kinda new to DIY car fixes. Is this a fairly easy job?
post #4 of 9 Old 09-23-2013, 03:17 AM
james_2k
2003 WJ
yes. just make sure not to move the iac by hand as it can break apparently. (although i did and it was fine after)
james_2k is offline
post #5 of 9 Old 09-23-2013, 06:53 AM
JTS97Z28
My 02 Overland occasionally had high idle at startup. The problem went away after cleaning the throttle body and IAC.
JTS97Z28 is offline
post #6 of 9 Old 09-23-2013, 07:00 AM Thread Starter
haddadin23
Thanks everyone for your replies really appreciate it! gonna try it out tomorrow morning!
post #7 of 9 Old 09-23-2013, 07:45 AM
briandor
Just had the same thing on the Overland I just bought and it was the TPS. So if the IAC doesn't do it try replacing the TPS. Both are right next to each other. Also if the TPS is going bad a lot of times you'll have other symptoms like wanting to kick in and out of overdrive on the highway.
briandor is offline
post #8 of 9 Old 09-23-2013, 08:13 AM Thread Starter
haddadin23
While driving on the highway. While trying to speed up the rpms drops down to about 1500. Will only go up to about 2100 going like 80mph can that be because of the tps or iac?
post #9 of 9 Old 09-23-2013, 10:21 AM
briandor
No. That sounds normal. You'd see the rpms bouncing up and down as the overdrive kicks in and out but the speed stays the same. As the TPS gets worse you'll really know as the transmission starts going crazy and doesn't know what gear to be in. From what you described it sounds like the TPS is ok and I'd work on cleaning the IAC and see if that does the trick.
briandor is offline
