High Idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > High Idle
Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-04-2012, 01:58 PM   #1
Rooster71
High Idle
I have 02 with the 4.7 engine. For past week I have noticed that the idle climbs when I am sitting still in park. It does not go extremely high, but high enough that it is noticeable. It will stay that way for a few seconds and then drop. It will do this several times until I start driving. I have not noticed anything while I am driving. Any ideas where to look?
Rooster71 is offline   Reply With Quote
Unread 02-04-2012, 02:40 PM   #2
Jeepgcl9947
I have the same problem. I've fixed like every sensor, and still does it!
Jeepgcl9947 is offline   Reply With Quote
Unread 02-04-2012, 02:59 PM   #3
maloj2003wj
I had the same problem with my 4.0L . My mechanic changed the IAC first, but it still happened. I changed my TPS sensor myself today and cleaned the throttle boddy. It stopped. Hopefully won't happen again. If it does I'll let you know. The car runs much better after cleaning the throttle body though!
maloj2003wj is offline   Reply With Quote
Unread 02-04-2012, 03:00 PM   #4
Gran_Paradiso
2003 WJ 4.7L
2003 WJ
When mine did that I changed the TPS (Throttle Position Sensor). Inexpensive easy fix.
2003 WJ 4.7L LTD Quadradrive * Kolak 3" Catback exhaust with Flowmaster 70 and Magnaflow tip * Spyder CCFL Halo projectors * Raptor 4500k 35watt HID's low beams * K&N Drop box air filter * Bilstein HD shocks * Stillen Cross Drilled Rotors and Metal Matrix Pads.
Gran_Paradiso is offline   Reply With Quote
Unread 02-04-2012, 03:06 PM   #5
Jeepgcl9947
Unread 02-04-2012, 10:15 PM   #6
maloj2003wj
Have you checked for any vaccum line leaks?
Unread 02-04-2012, 10:22 PM   #7
Jeepgcl9947
Yeah, over and over again.
Unread 02-05-2012, 02:41 AM   #8
piraterig
mine does this occasionally in park. 04 4.0
04 WJ stock, saving funds for mods
95 ZJ 30x9.50s kumho at
96 XJ sport with stuff, sold
piraterig is offline   Reply With Quote
Unread 02-05-2012, 08:30 PM   #9
Bkhager
2011 JK Wrangler
I swapped motors in my 96 xj and I'm being plagued with high idle. Changed iac, tps and checked for vacuum leaks, still no fix!
Hebrews 2:9
http://www.bethanybaptistmissionary.org/
Bkhager is offline   Reply With Quote
Unread 02-10-2012, 09:30 PM   #10
OTownDaddy
2007 XK Commander
I have the exact same issue. Causes a clunk when I shift out of park if the rpms are up do to the tranny engaging at the higher rpm. So the list of fixes are (from what I gather here):
* TPS replace
* throttle body cleanup
* vacuum leaks
So, wouldn't you notice other problems if it was a vacuum leak?
I was also wondering, what is the order of the list with respect to cost? TPS cheapest, then throttle body? What about in terms of difficulty?
OTownDaddy is offline   Reply With Quote
Unread 02-11-2012, 06:04 PM   #11
maloj2003wj
Its all pretty easy the tps is like $35, you can replace it without cleaning the throttle body, but i would suggest you do. You would also need the throttle body gasket if you are gonna do it. Well if you have a 4.0 if 4.7 its reusable. The gasket is like $3.0 so its all pretty cheap. In terms of difficulty its all pretty easy as well you just need the right tools. Heres a detailed description on how to do it http://www.wjjeeps.com/service/tbody.htm
Let us know what the result is
2002 Overland|4.7 HO|545RFE|Factory tow hooks and hitch
KOLAK'S 3" = OME HD SPRINGS * BILSTEINS * JKS FRONT TRACKBAR * ADDCO REAR SWAY BAR * IRO EXTENDED LINKS
