High Fuel Pressure - Bad Filter/Regulator? - JeepForum.com
post #1 of 3 Old 11-02-2011, 12:39 PM Thread Starter
3JsWJ
I just checked my fuel pressure last night and it was 52 psi with the key on but when started it jumped to 62 psi. Increasing the throttle would make the pressure bounce and then settle back down at 62 psi with constant throttle.
I know the FSM says 49 +-5 psi. I am assuming that the problem is with the pressure regulator (fuel filter). I had just replaced it last year with a WIX.
The reason for the fuel pressure test is poor fuel mileage 12-13mpg. I've already done, fluids, filters, cleaned TB, new TPS, new IAC, plugs, and just last week O2s.
Has anyone had this high fuel pressure or has anyone had problem with the WIX fuel filters?
3JsWJ is offline
post #2 of 3 Old 11-03-2011, 07:13 AM Thread Starter
3JsWJ
Can anyone recommend the best fuel filter to use? WIX, Purolator, Fram,...Mopar?
3JsWJ is offline
post #3 of 3 Old 11-03-2011, 10:00 AM
kfxnando
would like to see what info comes out here, am in a similar situation, just haven't measured fuel pressure, however my one smells very rich, and smokesat idle, smells very rich, changed even fuel filter as well however fuel consumption is good
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
1999 wj fuel pressure regulator & mpg dayneseditz WJ Grand Cherokee Forum 11 03-09-2012 10:57 AM
High Pressure Fuel Pump leak / Change Seals? dsl55 WJ Grand Cherokee Forum 13 12-31-2011 05:53 AM
fuel filter/ fuel regulator? rubyred98xj WJ Grand Cherokee Forum 4 10-15-2011 01:59 PM
Fuel filter, pump or regulator??? Bluedragon WJ Grand Cherokee Forum 10 03-10-2011 12:13 PM
99 Grand Cherokee Fuel Filter Regulator phjohnso WJ Grand Cherokee Forum 1 12-23-2003 07:35 PM
