HID fogs won't turn on - JeepForum.com
post #1 of 12 Old 04-09-2014, 05:18 PM Thread Starter
tauruspt2
Got a ddmtuning hid foglight kit for my 04 4.7L wj. Already had one in before but one of the lights wouldnt turn back on which is why I bought a new kit. Unplugged everything to reinstall the new bulbs and ballasts and installed the new one. Bulb to ballast, and then 1 more wire to the bulb.
But the fog light won't turn on. Try rewiring a different way and heard a buzzing noise so I immediately unplugged it lol.
I am a noob to this I need some help
WJ Limited 2" IRO Lift, Bilsteins, MOOG steering stabilizer, Mamba M13x rims
Cooper Discover AT's
tauruspt2 is offline
post #2 of 12 Old 04-09-2014, 05:58 PM
Vaporhead
ddmtuning is junk these days. They used to be quality kits, but they are no longer that way. It should just be plug n play, right? Did you try swapping sides? Did you get the relay kit?
Vaporhead is offline
post #3 of 12 Old 04-09-2014, 06:35 PM Thread Starter
tauruspt2
no didn't think I needed a relay from what i have read. Had previous one installed just bought a new ballast and bulb
post #4 of 12 Old 04-09-2014, 09:06 PM
Photochop
Only issue I've had with them is polarity change. Pull the connector from the vehicle connector into the ballast and turn it around and tape it on so it doesn't slip off if you haven't tried that already.
Photochop is offline
post #5 of 12 Old 04-09-2014, 09:16 PM
1999wjlimited
X2 I had to do this when I had my hid fogs.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #6 of 12 Old 04-09-2014, 09:35 PM
imaguy3
Make sure your ground is good. It might appear good but not quite be good enough.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #7 of 12 Old 04-10-2014, 05:13 AM Thread Starter
tauruspt2
Just switch the pos and neg?
post #8 of 12 Old 04-10-2014, 05:13 AM Thread Starter
tauruspt2
can you explain to me what this means lol
post #9 of 12 Old 04-10-2014, 05:53 AM
braddf
The buzzing noise is the ballast. They all do that if you listen closely
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
post #10 of 12 Old 04-10-2014, 07:06 AM
Photochop
Yes. The clip connector from the car to the ballast has the clip on one side where it clicks in. Pull it loose and turn it around and plug it in switching the pos/neg polarity. I've had this happen on several cars and they come on fine once you switch it. Be sure to wrap tape around the connection so it doesn't come loose after you test it.
post #11 of 12 Old 04-10-2014, 01:20 PM
Merc1973
Do you have the relay kit from DDM too?
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #12 of 12 Old 04-10-2014, 01:29 PM Thread Starter
tauruspt2
Switching it worked! Hooked it up taped it and bam they both worked. Switched both ballasts and it looks great.
Thanks for all the help guys I appreciate it
