helpful hints anyone? - JeepForum.com
post #1 of 7 Old 11-08-2013, 12:12 PM Thread Starter
ZJPunk98
Hi guys,
Installing my lift today in my 02 WJ. Any helpful hints with unbolting the top of the old shocks?
thanks
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #2 of 7 Old 11-08-2013, 12:56 PM
gold01wj
There should be a spot at the top of the stud to hold them with a wrench or socket while you loosen the nut.
2000 wj limited quadradrive 4.7 family vehicle-was stock, then lifted 4",now stock again
gold01wj is offline
post #3 of 7 Old 11-08-2013, 01:14 PM
2ndhandWJman
If you are replacing the front shocks with new ones, use a big vice grip to clamp onto the shock shaft, then use a socket/long extension to break off the upper nut. Or if you have a 4" angle grinder, use a cut off wheel and just cut the shock shaft off at the lower top mounting bushing.
2ndhandWJman is offline
post #4 of 7 Old 11-08-2013, 01:53 PM
imaguy3
When I did mine that was the hardest/longest part. On the passenger side especially I didn't have a lot of room, needed a stubby wrench and fraction of turns to tighten the new one down... took 5-10 min. just on that one...
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #5 of 7 Old 11-08-2013, 01:56 PM
ChrisHager
Administrator
ChrisHager's Avatar
Lift Install
Specifically:
Originally Posted by ChrisHager View Post
To remove the shock's top bolt, Nicholas grabbed the shock bolt directly below the bushing washer with a pair of plyers while I unscrewed the nut on the top side with an extension and an impact wrench (if you don't have one, get one. It makes this job so much easier!).
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6 of 7 Old 11-08-2013, 02:29 PM Thread Starter
ZJPunk98
I used a grinder to flatten the piston rod, then used vice grips and 15mm to crank the nut off. worked great
Erik
ZJPunk98 is offline
post #7 of 7 Old 11-09-2013, 07:23 AM
Cirruslydakota
I used vice grips on the old shocks at the very top. My new ones have a nut welded to the top to aid in removal. I also used air tools which made the job super easy.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
