-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   helpful hints anyone? (http://www.jeepforum.com/forum/f310/helpful-hints-anyone-1771225/)
ZJPunk98 11-08-2013 12:12 PM
Hi guys,
Installing my lift today in my 02 WJ. Any helpful hints with unbolting the top of the old shocks?
thanks
gold01wj 11-08-2013 12:56 PM
There should be a spot at the top of the stud to hold them with a wrench or socket while you loosen the nut.
2ndhandWJman 11-08-2013 01:14 PM
If you are replacing the front shocks with new ones, use a big vice grip to clamp onto the shock shaft, then use a socket/long extension to break off the upper nut. Or if you have a 4" angle grinder, use a cut off wheel and just cut the shock shaft off at the lower top mounting bushing. :thumbsup:
imaguy3 11-08-2013 01:53 PM
When I did mine that was the hardest/longest part. On the passenger side especially I didn't have a lot of room, needed a stubby wrench and fraction of turns to tighten the new one down... took 5-10 min. just on that one...
ChrisHager 11-08-2013 01:56 PM
2 Attachment(s)
Lift Install
Specifically:
Originally Posted by ChrisHager (Post 12751376)
To remove the shock's top bolt, Nicholas grabbed the shock bolt directly below the bushing washer with a pair of plyers while I unscrewed the nut on the top side with an extension and an impact wrench (if you don't have one, get one. It makes this job so much easier!).
:tea:
ZJPunk98 11-08-2013 02:29 PM
I used a grinder to flatten the piston rod, then used vice grips and 15mm to crank the nut off. worked great
Cirruslydakota 11-09-2013 07:23 AM
I used vice grips on the old shocks at the very top. My new ones have a nut welded to the top to aid in removal. I also used air tools which made the job super easy.
The time now is 03:11 PM.
