HELP!! Turn signal issue - JeepForum.com
post #1 of 19 Old 10-24-2013, 11:57 AM Thread Starter
JoeFTW
Unhappy HELP!! Turn signal issue
Hey everyone!
I just recently bought a 2001 Grand Cherokee with hopes to fix it up and drive it around. One of the issues that I am having is that the left turn signal does not work at all. The Right one works fine, and both hazards work fine. But when I hit the left turn signal, literally nothing happens. No noise no click no blink no light on the dash. Anyone have any ideas??
Thanks!
JoeFTW is offline
post #2 of 19 Old 10-24-2013, 12:55 PM
ace402
Do a quick search. Its probably your flasher relay under the steering column. The solder cracks and renders them useless.
ace402 is offline
post #3 of 19 Old 10-24-2013, 12:57 PM
wj4play
X2 but you can just re solder the crack - I did and no probs
Btw it is $$$$ and dealer only part
Sent from busted up iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #4 of 19 Old 10-24-2013, 01:01 PM
wj4play
Originally Posted by JoeFTW
Hey everyone!
Thanks!
Just re read this - the flasher is multi function so flashers etc would not work
Check the connections on the one tail light where the bulb holder screws on
wj4play is offline
post #5 of 19 Old 10-24-2013, 01:10 PM
ace402
Are you sure? I thought the flashers could still work. I currently have the same problem on my wj. If I hit the hazards and the the turn signal it will start working again sometimes. I'm on my phone or I would link to the other thread. Either way, do a quick search. There is fairly comprehensive thread out there
ace402 is offline
post #6 of 19 Old 10-24-2013, 01:38 PM
rdkendrick
2003 WJ
Also might want to check the connector on your multi-function stalk (turn signal actuator). Could also be a bad stalk. Not hard to get to or change out and you could probably find one in the junkyard.
Sent from my iPad using my fingers
rdkendrick is offline
post #7 of 19 Old 10-24-2013, 01:55 PM
wj4play
Positive ..
wj4play is offline
post #8 of 19 Old 10-25-2013, 01:40 AM
nolimitssjca
I had the exact same issue. Left turn signal didn't work and everything else did. It was the flasher relay. I got a used one for $10 bucks off a donor parts cars. It's the biggest relay in the middle of the top row on the left side of the dash.
1999 WJ 4x4, 1997 ZJ 4x4
1997 Mountaineer 4x4, 1996 Explorer 4x4
1972 Mustang Mach 1 351 Cleveland, 1972 Mustang Coupe 302
1970 Chevy C-20 350, 2002 Kawasaki Vulcan
nolimitssjca is offline
post #9 of 19 Old 10-28-2013, 05:54 AM
RiverMCK
2003 WJ
I had same issue, turn signal would work, then not work or stay on permanently. I pulled the relay, took it apart and solders were all good. I bought a replacement relay at NAPA for like $45 dollars. Could find one at junk yard too I suppose, but I decided to go new and not have to worry about it anymore.
RiverMCK is offline
post #10 of 19 Old 10-28-2013, 06:00 AM
ace402
So the Napa relay fixed it then
ace402 is offline
post #11 of 19 Old 10-28-2013, 06:14 AM
RiverMCK
2003 WJ
Yes sir. The NAPA relay looked identical to the OEM part and even had the Chrysler emblem on it. Pull the relay and check the solders first. Use the search function as there is a write up out there somewhere. If you can't see any broken solders, then I would just pull the trigger on a new one. If that doesn't fix it then I would suspect it's the turn signal arm assembly which is also quite easy to remove. I pulled mine out and inspected it before buying the new relay. Not sure what I was looking for but everything seemed intact. Might be a write up on how to check for proper electrical signal running through the turn signal assembly, but like I said, mine was fixed by replacing the relay. Good luck!
RiverMCK is offline
post #12 of 19 Old 10-28-2013, 07:01 AM
wj4play
Those tards .... Nappy - autozone orielys- advanced auto all told me it was a dealer only part and the dealer wanted $70+ get the relay on my 99 wj . That's why I went the solder route even though I needed a magnifying glass to see the crack
When did you replace it?
wj4play is offline
post #13 of 19 Old 10-29-2013, 08:59 AM Thread Starter
JoeFTW
Thanks guys, i really appreciate all the feedback. I didnt get a chance to do it this past weekend but i will get to it this week. Ill post what i find! Thanks again!
JoeFTW is offline
post #14 of 19 Old 10-29-2013, 08:06 PM
MuddyWJ
Joe I just performed surgery on my flasher relay today. if you are looking down at the points with the blades facing you, it's the 3rd from the right. 3 Philips screws and two 10mm bolts to pull dash apart. Top row of relays above your fuses, it's the big middle one. Kinda tight quarters but comes out easy enough. Good luck.
MuddyWJ is offline
post #15 of 19 Old 11-02-2013, 07:39 PM
link375
link375 is offline
