-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   HELP! tranny problems (http://www.jeepforum.com/forum/f310/help-tranny-problems-1759114/)
chwhite0783 11-04-2013 09:20 PM
I have a 99 grand and I am not getting third or fourth...no codes set. I replaced solenoids and transducer in trans and still no third or fourth.....however, when I do not get third or fourth if I stop and put in reverse for a second I will get third and fourth when I drive again until cycle key....and I do not get third and fourth manually shifting either. help losing my mind!
MadderThanMax 11-04-2013 10:23 PM
Try Disconnecting the TCM and reconnecting.. also get the fault codes read.. It sounds like you are in Limp Home Mode.
Relax_Jimmy24 11-04-2013 10:30 PM
i think you have to take it to the dealer and have them perform a quick learn since you replaced the solenoid and have them erase any transmission codes. correct me if am wrong. as i am in the process of replacing my solenoid pack
MadderThanMax 11-04-2013 10:52 PM
True! Yes, I think there was a flash drive update for them as well...
chwhite0783 11-05-2013 06:32 AM
Tried reset. No codes at all
MadderThanMax 11-05-2013 06:52 AM
Sounds like you have to bite the bullet here and put it in to A tranny expert.. I think it maybe a valve box issue.
The time now is 03:09 AM.
