Help with tires - JeepForum.com
post #1 of 12 Old 05-15-2013, 01:48 PM Thread Starter
Halo29
Help with tires
Alright so I put a 4" Rough Country Suspension lift in my Jeep over a month ago and I finally saved up enough money to buy bigger tires, I already bought new rims which are Black Rock Steel Wheel 997 Type 8 16x8" 5x5 Bolt Pattern Back Spacing 4 1/4". I was wondering what size people would recommend for me to put on, I'm not looking to stuff the biggest tires on it. I just want her to look good and I really like the General Grabber AT2's but I was wondering if anyone else had some suggestions.
Thanks.
Halo29 is offline
post #2 of 12 Old 05-15-2013, 02:18 PM
fast540
Depends on your intended usage but a 32" tire on stock wheels was as big as I could go without cutting sheet metal. I cut off the lower bit of my front bumper and run a protofab rear bumper. I didn't use the tc drop or the bumpstop extensions and did add limit straps. I cycled the susp through its travel without springs on the lift and set my jounce and bump limits based on that process. Off road disco'd I get a slight rub in the inner front wheel wells when fully flexed but just enough to make paint shiny
fast540 is offline
post #3 of 12 Old 05-15-2013, 02:20 PM
fast540
Pics
image-777637773.jpg   image-1472965798.jpg   image-4075625699.jpg   image-21725811.jpg
fast540 is offline
post #4 of 12 Old 05-15-2013, 04:42 PM
Jameswj4
I'm putting the rc 4in lift in the summer and I've been researching too rc suggest, and a lot of people suggest 265/75/16 (32s). And ive been looking at the grabbers AT2 as well and a lot of people love them I suggest them and they're not that expensive
'04 WJ "Sherry" 4.0L RCX 4in lift on 265/75/16 BFG ATs DD/Trail rig- uniden 505xl 4ft firestik- custom roof Rack- custom rear and front shackle tabs-
Jameswj4 is offline
post #5 of 12 Old 05-15-2013, 06:08 PM
skain8
skain8's Avatar
32's is most functional with very little trimming (i.e. plastic, not metal). Plus, you have the 4.0, so anything larger and it will be even more of a d o g.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #6 of 12 Old 05-29-2013, 02:43 PM Thread Starter
Halo29
Thanks everyone, I ended up getting the 265/75 16's in the General Grabber. I absolutely love the way it looks.
Halo29 is offline
post #7 of 12 Old 05-29-2013, 02:51 PM
stevesouthern
I like it!
stevesouthern is offline
post #8 of 12 Old 05-29-2013, 04:22 PM
Jameswj4
Sweet looks good
Jameswj4 is offline
post #9 of 12 Old 06-01-2013, 12:26 PM
zachbritt
do you rub at all??
zachbritt is offline
post #10 of 12 Old 06-13-2013, 07:59 AM Thread Starter
Halo29
A little n the front bumper.
Halo29 is offline
post #11 of 12 Old 06-13-2013, 01:54 PM
bigchevyman24
bigchevyman24's Avatar
Jeep looks good but those grabbers wear BAD.....like 20k miles only out of a set. Wish you the best on wear. Keep them balanced and rotated! I was going to suggest Treadwright before I got to the bottom and saw you already purchased some.
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline
post #12 of 12 Old 06-13-2013, 02:20 PM
stevesouthern
Looks cool
2000 wj 4.7 quadradrive, 2"bb, 8x16 'D' modulars 4" bs, 265/75/16 insa turbo dakars, glasspack exhaust, BRC LPG conversion, cut out front fenders.
