HELP SKIM module failure, dealership ripoff??? - JeepForum.com
post #1 of 8 Old 10-25-2012, 09:50 AM Thread Starter
jrafols
Wj HELP SKIM module failure, dealership ripoff???
So i think i just got ripped off by the dealership for $700.
I lost the only key i had to my 03 grand cherokee, so i bought two programmable keys on ebay (not OEM). got them cut and took them to the dealership.
the Jeep's battery was low since it hadn't run in about four weeks.
I got it towed to the dealership to the get new keys programmed and after a long wait in the customer service area. the rep comes back saying that the keys cannot be programmed because since the battery was low, the SKIM module lost its programming and i would need a new SKIM module and battery.
A new SKIM and battery were put in but the new keys would not program so I had to buy a OEM key from the dealership to make it work.
in the end, my question is, Can the SKIM module go bad for a dead battery??
jrafols is offline
post #2 of 8 Old 10-25-2012, 11:14 AM
funkduck
2015 KL Cherokee
What?
My keys work after I disconnect the battery, even when it was disconnected for 3 days..
Sounds bogus to me. If anything, maybe the aftermarket keys you bought were bunk to begin with OR the stealership was butthurt that you didn't go straight to them for keys and never actually even tried mating the aftermarket keys.
If their original argument was that the SKIM was bad because the aftermarket keys wouldn't program and then they replaced the SKIM, and the aftermarket keys still wouldn't program ... then they just ripped you for the cost of a SKIM & install - and the vendor of the aftermarket keys may have ripped you on bunk keys.
funkduck is offline
post #3 of 8 Old 10-25-2012, 11:32 AM
ZB_WJ
Sounds like non-chipped keys
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #4 of 8 Old 10-25-2012, 11:34 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You got scammed on the sentry key module if that's the line they fed you
ratmonkey is offline
post #5 of 8 Old 10-25-2012, 12:33 PM
Indy
Indy's Avatar
Id have a hard time believing anything programmed is on volitile memory, at least until I see pictures of every piece constantly attched to a battery before during and after the ride getting built at the factory.
I hope they at least gave you a reach around.
I'm the only gay eskimo.
Indy is offline
post #6 of 8 Old 10-25-2012, 12:36 PM
ZB_WJ
Dealership?
Mmm, For ripped off, you will be, young padowan (yoda)
I would ask for the old one back and test it somehow.
ZB_WJ is offline
post #7 of 8 Old 10-25-2012, 02:06 PM
MeanGreenZJ
If the SKIM module lost its programming, the dealer has the tools to reprogram it. My guess is that they couldn't get into programming mode due to the factory pin code not working. This can happen for a few reasons such as someone swapping the SKIM module and PCM into your Jeep from another at some point.
MeanGreenZJ is offline
post #8 of 8 Old 11-08-2013, 02:12 PM
Errol7
Dilema
I am in the same dilema, bought a new FOB key, battery died and now the FOB does not work. The old grey standard key still works which is also an eBay key. They are trying to say SKIM but the old key still works so I have an estimate of $600 for new skim and reprogram of keys. Argh!!
Any suggestions
Buy a new Key??
Another dealer said the key was good but they didn't try a program.
Errol7 is offline
