HELP please - JeepForum.com
post #1 of 6 Old 06-20-2013, 07:09 PM Thread Starter
Mchammer
HELP please
Hey guys I have a 99 grand Cherokee Laredo. It's all time 4x4. I don't know much about mechanical work which is why I need help! When I turn the steering wheel it pops really bad. It also pops when driving down the road. Any help would be greatly appreciated.
Mchammer is offline
post #2 of 6 Old 06-20-2013, 07:36 PM
lazyWJ
2006 XK Commander
Does it pop when you turn the wheel while you're stationary or moving? It sounds CV/driveshaft related but some more details would be helpful. Do you have Quadra Drive or Quadra Trac II?
McHammer eh? I used to know a McHammer back in my younger years. That guy was too legit.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #3 of 6 Old 06-20-2013, 08:23 PM Thread Starter
Mchammer
It's a qaudeatrac2 and no it's only does it once the vehicle stars moving. After about 55 mph it doesn't do it very bad but still pops a little. But the harder you turn the steering it starts popping really bad. Thanks for the help!
Mchammer is offline
post #4 of 6 Old 06-20-2013, 08:53 PM
tjl1388
Sounds like the rezeppa(sp?) joint going bad on the front driveshaft.
tjl1388 is offline
post #5 of 6 Old 06-21-2013, 03:26 AM
cykaaro
Remove the front driveshaft. Does it still do it? If yes, then check your CV axle shafts. If no, then it's most likely the driveshaft, either the rezeppa joint(s) or ujoints, depending on what type of driveshaft it is. If it is the rezeppa type, is the boot on the t-case side rippped open? You'll usually hear a fairly loud humming if it is that joint as well.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #6 of 6 Old 06-21-2013, 09:26 AM Thread Starter
Mchammer
thanks for the help, ill check it out and keep you posted(:
Mchammer is offline
