Help with overhead console, buttons not working! - JeepForum.com
post #1 of 6 Old 09-26-2017, 01:00 PM Thread Starter
Nerd766
Hello, fellow Jeep friends!! I have a recently bought 2000 WJ and I was wonder if anyone could help me with my overhead console. I will try to attach a photo but if not, the console itsel just has (from left to right) the buttons 'C/T', Reset, Step, Menu. All buttons don't work except the Menu button. I've read through different forums but can't find the solution. As I press the Menu button, it allows me to choose through different options but I can't press any of buttons to change the settings. Anyone else have this problem??? Any suggestions would be amazing!
Nerd766 is offline
post #2 of 6 Old 09-26-2017, 02:11 PM
Double E
Double E's Avatar
I would start by pulling down that assembly and seeing if it is connected at the back correctly. IIRC, there is a single screw (torx-type?) towards the back that you can remove to pull down the console.
I would also get the upgraded console that has the garage door opener in it. A junkyard or members here usually have them.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 6 Old 09-26-2017, 03:16 PM Thread Starter
Nerd766
Thanks for the suggestion! Would you know if this would be a direct plug in? Do I need to alter or add anything else? Is my vehicle set to connect to the upgraded console? Sorry, I'm a Jeep noob.
Nerd766 is offline
post #4 of 6 Old 09-26-2017, 07:38 PM
wolf_7669
It should be a direct swap with no modification. The other console just has a universal garage door transmitter built in.
wolf_7669 is offline
post #5 of 6 Old 09-27-2017, 05:51 AM
Double E
Double E's Avatar
Yes. Direct swap. I did it recently.
All jeep noobs must go read www.wjjeeps.com
For example, on my Freedom edition, apparently it is called that because it is "free" from all options of convenience aside from some rock rails, the 4.7HO and chrome tow hooks.
It's a weird package but at least Jeep made it pretty easy to add stuff you actually want back in.
Double E is offline
post #6 of 6 Old 10-05-2017, 10:20 AM Thread Starter
Nerd766
Thank you all for your assistance! This forum is amazing
Nerd766 is offline
