Help!!! Over heating 4.0 Grand Cherokee - JeepForum.com
post #1 of 26 Old 11-02-2013, 12:46 PM Thread Starter
Robert1964
I'm brand new to this forum and I'm looking for help. I have a 99 Grand Cherokee 4.0 that is over heating. New fan and relay and radiator recently installed. Drove it a couple weeks with all these new parts with no problem. All of a sudden, it over heats. Fan is running fine and when I opened it to replace the thermostat, it did not even have one. I've put a thermostat back in it and when you crank it it runs great. No water in the oil. But when you crank it, the temperature rises and never stops. Is this a blown head gasket or possibly something else.
Robert1964 is offline
post #2 of 26 Old 11-02-2013, 02:12 PM
new2site
Try burping the radiator (although the fact that it was fine for a couple weeks AFTER the radiator replacement wouldn't seem like this would be the problem) If you do see a lot of air bubbles replace radiator cap too if radiator didn't come with one.
Maybe your heater core's clogged up although this shouldn't cause major overheating like you're getting.
Get any piece of pipe with the inside diameter of your heater core hoses and bypass your heater core (join hoses together) and see what the needle does.
Any large hardware store (Home Depot / Lowes ) should have something to fit that bill....plumbing department: pvc,galvanized, or copper pipe...etc..
new2site is offline
post #3 of 26 Old 11-02-2013, 03:29 PM Thread Starter
Robert1964
Thanks....I'll try burping it....been sitting a while now so I'll have to charge the battery. But its worth a shot.
post #4 of 26 Old 11-02-2013, 03:30 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Possibly a bad new thermostat or installed wrong. I would pull it again and see what happens.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #5 of 26 Old 11-02-2013, 03:52 PM
new2site
Yep...could be...take it out and boil it on your stove...
new2site is offline
post #6 of 26 Old 11-02-2013, 04:30 PM Thread Starter
Robert1964
It was overheating without any thermostat in it at all......I've put a 180 thermostat in it myself and yes its in the right way.....LOL....made that mistake once as a teenager and make sure these days not to do it again.
post #7 of 26 Old 11-02-2013, 05:41 PM
MuddyWJ
It's a possibility that you have a busted water pump. It's the only thing left untouched correct?
MuddyWJ is offline
post #8 of 26 Old 11-02-2013, 07:05 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
Sorry I did not pick up on that it was overheating before. Like MuddyWJ said, check your water pump.
Lifetime member #13
post #9 of 26 Old 11-02-2013, 07:28 PM
new2site
I was thinking that too..but usually they start leaking profusely out the weep hole..and I assume he hasn't noticed any leaks/coolant level drops.
Possible the shaft broke between pulley and impeller...but not common.
I realized that you had stated that after my last post...had a little brain slip.
new2site is offline
post #10 of 26 Old 11-02-2013, 09:30 PM
MuddyWJ
I was thinking more like the impeller itself is broken. Correct me if I'm wrong but aren't they plastic from the factory.
MuddyWJ is offline
post #11 of 26 Old 11-03-2013, 05:20 AM
michiganmaveric
Got Beer?
2011 JK Wrangler
I don't know about factory, but one I got from NAPA was and disintegrated the impellers after about 3 years. Started to overheat when driving 60MPH then would cool when idling. No blades left on the pump.
Lifetime member #13
post #12 of 26 Old 11-03-2013, 01:21 PM Thread Starter
Robert1964
Thanks.....I'll check the water pump first chance I get.......I've never had one loose the impellers but if they are made of plastic, then thats a real possibility.....All my water pumps (on other vehicals) have started leaking out the weep hole first. I will be pulling the pump after hearing this. Its the only thing I have not checked. Thanks for the info and any more info will be greatly appreciated.
post #13 of 26 Old 11-03-2013, 02:30 PM
McGR
2007 XK Commander
The plastic impeller cut loose on mine a few years back. It wasn't until after replaced the radiator and thermostat, that I figured out what was going on. This is not your typical leaky seal type water pump failure. In this failure nothing leaks the impeller simply breaks loose from its shaft and no longer circulates coolant.
McGR is offline
post #14 of 26 Old 11-03-2013, 03:42 PM Thread Starter
Robert1964
Now I'm really suspecting the water pump after hearing this......I'll be pulling it tomorrow......Anyone else had this issue? I'm so hoping this is the problem and not a head problem.
post #15 of 26 Old 11-03-2013, 09:06 PM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
I doubt that a busted head gasket would cause overheating; it's the other way around. Now once it gets to operating temperature and the thermostat opens, grab the upper hose (a good idea to wear gloves), you should feel it is under pressure. If that's not the case, that could be a sign the water pump is gone.
IMO it's either the water pump or the CTS is giving you a wrong reading (in that case it's not overheating). You might want to get one of those IR thermometer and check the actual temperature at the thermostat housing and compare to the gauge reading on your dashboard.
rep-tile is offline
