Help!, No turn signals or heater controls - JeepForum.com
post #1 of 4 Old 06-11-2013, 11:24 AM Thread Starter
Delmega
Lightbulb Help!, No turn signals or heater controls
We managed to hotwire our trailer lights into our 2001 Jeep Grand Cherokee to pull our boat to the lake. When we did this we lost both turn signals and the control panel for the heat, blower, and A/C. We have changed out all of the relays under the steering column and the control panel for the heater. We still do not have turn signals or control panel. We have tested the blower motor and it is working fine. If anyone can help with any additional things to try please let us know.
Thanks
Delmega is offline
post #2 of 4 Old 06-11-2013, 11:28 AM Thread Starter
Delmega
Also I forgot to mention that the flashers, brake, running and headlights all still work.
Delmega is offline
post #3 of 4 Old 06-11-2013, 03:55 PM
oldfamilyguy
Did you check for any blown fuse? That would be my guess, you caused a short.
oldfamilyguy is offline
post #4 of 4 Old 06-11-2013, 09:12 PM Thread Starter
Delmega
We had checked all of the relevant fuses when this first happened and all checked out fine. We rechecked everything and I downloaded a complete copy of the fuse schematics. In our Haynes manual it should fuse 23 as the heated seats but once we got the complete schematics we discovered that fuse 23 also runs the heater controls and the blinkers. Once we switched out the fuse everything is working great.
Delmega is offline
