Help. . New Jeep WJ w/ electrical problems - Page 2 - JeepForum.com
post #16 of 72 Old 09-20-2012, 02:25 PM
super98lsc
If the back end is VERY noisy like mega-road noise roaring its likely the axle bearings. I would inspect it all as mentioned and replace the axle bearings while your at it.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #17 of 72 Old 09-21-2012, 12:48 AM Thread Starter
protonspring
I do hear a wheel bearing, but the very LOUD noise from the back end is different. If I'm coasting. . there is NO noise. If I'm driving, or accelerating, then it is VERY loud. Seems like this might more indicate a bearing other than in the axle or wheel. I'll fix the wheel bearing(s) first, then see what's next. Thanks for all the help!
protonspring is offline
post #18 of 72 Old 09-21-2012, 12:50 AM Thread Starter
protonspring
Oh. . and "QD" . . is that QuadraDrive ? I think I just have "Select-Trac" . . . not QuadraDrive. Sorry, I haven't had time to do any research here yet. Do I still need the limited slip differential fluid?
post #19 of 72 Old 09-21-2012, 02:17 AM
Thomahawk
Nope and no FM needed.
Buildthread
Thomahawk is online now
post #20 of 72 Old 09-21-2012, 08:38 AM Thread Starter
protonspring
Seems like if I'm going to take apart the rear, then I should just replace all the bearings. How many are there? Is there a rear-bearing kit someone would recommend?
post #21 of 72 Old 09-21-2012, 08:49 AM
spazzedface
2009 JK Wrangler
I had the same issue of the worn lock cylinder and ended up replacing the lock cylinder with a junkyard one. There were a few times were I started it with my Acura Integra key and didn't notice it until I pulled it out
2009 JK Unlimited
2000 WJ Grand Cherokee V8 sold at 251,000
The bitterness of poor quality remains long after the sweetness of low price is forgotten
spazzedface is offline
post #22 of 72 Old 09-22-2012, 10:53 AM Thread Starter
protonspring
CEL came on today . . . cylinder 3 misfire. . . new spark plugs. Runs WAY better. Looks like spark plugs had never been changed. . jeeze.
post #23 of 72 Old 09-22-2012, 10:54 AM Thread Starter
protonspring
I'm pulling off both rear axles today, and will press on new bearings this weekend. Wish me luck. . never done something this big before.
post #24 of 72 Old 09-22-2012, 07:47 PM Thread Starter
protonspring
Wow. Taking the rear axles out was super easy. Actually, it was easier than doing brakes. Wheels off, two bolts for caliper removal, 4 bolts for bracket removal, slide hammer pulled out the axle in 3 whacks. Had both axles out in 20 minutes. I can't believe I almost paid someone $400 to do this. Will press on new bearings on Monday.
post #25 of 72 Old 09-24-2012, 08:37 AM Thread Starter
protonspring
Came out this morning, and the interior lights were on. . . strange. No one has touched the jeep all night. I opened and closed a the rear driver side door, and they turned off. Dang. . either means another wire short, or a bad door switch. I'll probably just start disconnecting switches until this behavior stops. Any other reason why the interior lights would just come on randomly while the jeep is just sitting there?
post #26 of 72 Old 09-24-2012, 10:38 AM
ZB_WJ
One thing I love about The WJ. Fairly simple to work on. My aunt has a Nissan Pathfinder and I will not touch that thing. Talk about cluster ****. God bless American engineering!
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #27 of 72 Old 09-24-2012, 11:05 AM
wjguru86
The wiring you removed was for a key bypass for a remote starter. The connector would've plugged into a "coffin box" that would hold a key. And like you said the ring went up to the key cylinder to transmit the transponder code in the key to the cylinder.
wjguru86 is offline
post #28 of 72 Old 09-24-2012, 05:52 PM
outofrng623
Check the boots in the door as mentioned earlier. I have an 04, rear speakers didn't work. Had a complete stereo setup and while my guy was doing it, he found 8 broken wires between the two back doors. He fixed them for me. This Saturday, windows stopped working. Sunday I took apart the boot, two broken wires. I fixed them and all is well...Until the next wire snaps. If it's not that, check the switch at the door (dont know technical name) that opens and closes the circuit when the door is closed and opened.
outofrng623 is offline
post #29 of 72 Old 09-24-2012, 05:59 PM
outofrng623
Excellent link. I just happened to be reading through this thread and saw this. Just so happened I had broken wires in my door the other day and then some lol . I knew one was for the windows, but I wasnt sure about the other. Was going to search it out tonight...Saw this link, went to it and figured it out. THANKS
Originally Posted by 2001WJv8 View Post
http://www.bbbind.com/tech_database.html
check out this site, all the tsb's and diagrams you could ever want
post #30 of 72 Old 09-24-2012, 09:32 PM Thread Starter
protonspring
Well . . I got the axles back in today. It was pretty easy. However, the noise is still there. I checked transmission fluid, and rear differential fluid. Is there a separate reservoir for the transfer case? Perhaps that is low on fluid.
Electrical problems!!!! :( BeepBeepJeep777 WJ Grand Cherokee Forum 7 06-14-2012 01:44 PM
2000 jeep wj electrical problems BLUZTJ WJ Grand Cherokee Forum 0 02-24-2012 05:51 AM
All electrical problems with my wj. HELP!! jlgo222 WJ Grand Cherokee Forum 15 10-25-2011 07:34 PM
04 4.0 electrical Problems erand85 WJ Grand Cherokee Forum 0 06-02-2011 07:52 PM
Electrical problems in 1999 Jeep Grand Cherokee BDASigEp WJ Grand Cherokee Forum 3 06-02-2010 10:14 PM
