Help needed with front CV joint drive shaft - JeepForum.com
post #1 of 11 Old 07-24-2010, 04:56 PM Thread Starter
jeepsterguy
2011 WK
I have a 2001 WJ. The front drive shaft has a CV joint at the transfer case side. The rubber boot of the CV joint cracked and needs replacement. I checked the dealer and autoparts, no luck finding it.
If you know where I can get the boot, please let me know.
Thanks.
jeepsterguy is offline
post #2 of 11 Old 07-24-2010, 05:41 PM
TJSWJ
I dont think the make a boot for that. People dont really rebuild cv shafts all that much anymore. So there isnt much of a market for them. But they used to make these things called split boots for cv axle shafts. That might help you out a little bit if you can find one.
TJSWJ is offline
post #3 of 11 Old 07-24-2010, 05:52 PM Thread Starter
jeepsterguy
2011 WK
I am familiar with the split boot, it would not work on this.
I don't want to buy a new DS just because of the boot.
I discovered it today, Saturday, when the drive shaft shops are closed. I plan to call Monday.
In the mean time I am trying to get ideas where I might find the boot.
post #4 of 11 Old 07-24-2010, 08:29 PM Thread Starter
jeepsterguy
2011 WK
Anybody know if it is possible to get the whole CV joint?
post #5 of 11 Old 07-25-2010, 01:07 AM
ZJ5point2GCL
the local driveline shop here has anything and everything driveshaft related, i would wait until monday and give them a call. i found the auto parts stores next to useless.
and yes it is possible to get a whole new cv assembly
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #6 of 11 Old 07-25-2010, 07:55 AM Thread Starter
jeepsterguy
2011 WK
I am thinking of taking it apart and trying to fit an axle CV joint boot.
post #7 of 11 Old 07-25-2010, 09:46 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
whole different size joint.
ratmonkey is offline
post #8 of 11 Old 07-25-2010, 06:17 PM
greyfox
I just replaced the CVJ boot on my '00 GCL. I had no trouble finding a replacement boot for about $10 (at O'Reilly's). The trouble I had was with the boot clamp. They didn't have a clamp tool to rent so I messed up the one that came with the boot and had to find a clamp that didn't require a tool (Autozone).
You'll have to pull the axle and maybe deal with some rusty parts. You'll need a 13mm 12-spline socket and a 5 ft. pipe to use on your breaker bar for pulling the axle nut (30mm socket). Otherwise, standard tools apply.
Don't mess around with a split boot. They're difficult to install and they don't hold up.
If you take it to a shop, the labor shouldn't be more than an hour.
greyfox is offline
post #9 of 11 Old 07-25-2010, 07:40 PM Thread Starter
jeepsterguy
2011 WK
I'm afraid I didn't make myself clear. The boot is on the front driveshaft, not the axleshaft.
The CV joint is bolted on the transfer case.
post #10 of 11 Old 07-25-2010, 08:36 PM
greyfox
Sorry, I missed that.
greyfox is offline
post #11 of 11 Old 07-28-2010, 12:49 AM Thread Starter
jeepsterguy
2011 WK
I took the driveshaft to a shop. At first I asked him to grease and replace the boots. The splines were found worn so I exchanged my DS for one he had previously overhauled for $175.
cv driveshaft
Need a NEW CV joint for front drive shaft tjsgrecc ZJ Grand Cherokee Forum 19 12-10-2009 08:32 PM
96 GC front drive shaft cv joint rjs1956 ZJ Grand Cherokee Forum 1 08-06-2009 12:17 AM
front drive shaft CV joint rjs1956 ZJ Grand Cherokee Forum 2 08-03-2009 08:45 PM
Front Drive shaft CV joint busted.....HELP! branman444 ZJ Grand Cherokee Forum 27 12-18-2007 08:55 AM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 09:17 PM
