Help naming a part - JeepForum.com
post #1 of 9 Old 07-15-2013, 01:22 PM Thread Starter
jgs99wj
Help naming a part
I am working on replacing the rear pinion seal on my 99 WJ with a 35c rear axle. I have this part that I damaged while pulling the seal and I have no ideal what to call it. It is a small circular cap that fit over the seal, in between the seal and the yoke. It looks like a oil slinger or shield. When I look at a diagram of my axle it doesn't show there is suppose to be anything between the yoke and the seal. No part number on it. Any help naming it would be helpful. Thanks.
jgs99wj is offline
post #2 of 9 Old 07-15-2013, 02:11 PM
SirCussFreq
Best I can tell from the service manual, it could maybe be either a shim or the oil slinger? Collapsible spacer perhaps?
I'm kinda shooting in the dark here, sorry if it's not helpful Can screencap other pages if you give me a better idea of what to look for / what diagram you want to see.
These are the initial steps listed to remove the pinion gear:
PINION GEAR/RING GEAR
REMOVAL
NOTE: The ring and pinion gears are serviced as a
matched set. Never replace one gear without the
other gear.
(1) Raise and support vehicle.
(2) Mark pinion yoke and propeller shaft for
installation reference.
(3) Disconnect propeller shaft from pinion yoke
and tie shaft to underbody.
(4) Remove differential from axle housing.
(5) Place differential case in a vise with soft metal
jaw.
(6) Remove bolts holding ring gear to differential
case.
(7) Drive ring gear from differential case with a
rawhide hammer (Fig. 71).
(8) Hold the pinion yoke with Spanner Wrench
6958 and remove the pinion yoke nut and washer
(Fig. 72).
(9) Remove pinion yoke from pinion shaft with
Remover C-452 and Wrench C-3281 (Fig. 73).
(10) Remove pinion gear from housing (Fig. 74).
SirCussFreq is offline
post #3 of 9 Old 07-15-2013, 02:42 PM Thread Starter
jgs99wj
Thanks. Maybe the oil slinger. Dealership says that part doesn't exist though.
jgs99wj is offline
post #4 of 9 Old 07-15-2013, 04:42 PM
Krom
you sure its not just part of the seal?
Krom is offline
post #5 of 9 Old 07-15-2013, 04:54 PM
cykaaro
We did my rear seal a month or so ago. Seal was one piece that we removed and then put the new one in, and the yoke back on. Much like a rear TC seal. How does it go exactly on the axle? Where does it sit? and which way?
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #6 of 9 Old 07-15-2013, 05:07 PM
cykaaro
Here's a blowup of the axle
pinion seal part 14:
pinion seal part 15:
pinion outer bearing kit part 13:
pinion crush spacer part 4:
pinion shim kit part 29:
cykaaro is offline
post #7 of 9 Old 07-15-2013, 05:10 PM
cykaaro
My seal looked exactly like part#15 when we did it. We simply removed the old seal and put in the new one. Reattached the yoke, and done. Nothing looked like that part at all. I've got a dana35 in my '00 and is like the WJ axle shown in the blowup.
cykaaro is offline
post #8 of 9 Old 07-15-2013, 05:11 PM
cykaaro
This is a pic of the master overhaul kit
All found here:
wj-wg-grand-cherokee/34/rear-axle-dana-35/
cykaaro is offline
post #9 of 9 Old 07-15-2013, 05:15 PM
cykaaro
Only thing I can come up with is maybe that's in the end, and the seal goes into it somehow? or somehow was apart of the seal that was in it? But doesn't look like anything I dealt with doing mine.
cykaaro is offline
