Help with my Grand Cherokee - JeepForum.com
post #1 of 10 Old 05-22-2010, 05:41 PM Thread Starter
sracherla
Guys,
I recently purchased a used 2001 Grand Cherokee RWD and have a bad problem with it. It throws engine misfire codes 0300 0303 0304. It is my first jeep and it is great but for this one big problem.
I got the de-carb process done and it ran fine for a couple of months. The codes are back again and the mechanic is talking about replacing coils - each at about $400 bucks a pop.
The jeep has 70K miles.
I don't know if I should get this repaired or just get rid of it. Feels like I am throwing good money after bad.
Any thoughts, ideas or suggestions.
- Clueless Jeeper
sracherla is offline
post #2 of 10 Old 05-22-2010, 05:49 PM
spawnofsatan
maybe a faulty injector
spawnofsatan is offline
post #3 of 10 Old 05-22-2010, 05:55 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its real easy to rule out a coil pack.
They are all interchangable.
You can swap them out and see if the misfire code follows the coil pack.
The coil packs are $30-40 each from the dealer and are extremely easy to swap out.
I would think about finding a new mechanic.
Wheelin98TJ is offline
post #4 of 10 Old 05-22-2010, 07:12 PM Thread Starter
sracherla
More info...
What is the DIY procedure to replace the coils for the codes 0303/0304. I am guessing these two cylinders fire off of one coil?
Can anyone help me with the part # and the DIY process?
I am googling to find this info as I wait for a reply.
Thanks.
post #5 of 10 Old 05-22-2010, 07:28 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
I6 or V8?
Either way, get a new mechanic. At $400, he is raping you for at least $300 of that.
~James
ezflip is offline
post #6 of 10 Old 06-02-2010, 12:39 PM Thread Starter
sracherla
I6 ---
Is this an easy DIY job?
post #7 of 10 Old 06-02-2010, 12:46 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
To swap the coils? Yes it is very simple. It is 6 or so 10mm bolts along the pack, then unplug it from the back. The coils on an I6 are all part of one pack that runs across the passenger side of the engine. The PO of my I6 some how broke the pack and hot glued it back together. Wasnt throwing any codes or running rough when I bought it, but about 4 days later it was...I found that. New coil pack was about $80 IIRC.
~James
ezflip is offline
post #8 of 10 Old 06-02-2010, 01:05 PM
Wheelin98TJ
JEEP FREAK
When you previously said the mechanic was going to replace coils, that led me to incorrectly assume you had the 4.7 V8.
My prior advice about swapping coils does not apply to the I6. It only applies to the V8.
The coil rail for the I6 is part # 56041476AA and the list price is $242.00. You can get the part for as cheap as around $160 if you qualify for a discount.
I'm not sure if this part is available at the parts stores or not. It might be a dealer only item.
post #9 of 10 Old 06-02-2010, 01:08 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
I got mine at autozone. They actually had it in stock too.
~James
ezflip is offline
post #10 of 10 Old 06-02-2010, 02:32 PM Thread Starter
sracherla
Thanks, guys. I will get the part and try to swap it out this weekend.
Will let you guys know how it goes....
Update:
I found the part at the local autozone...
Next step: I will try to find a repair manual so that I can get this taken care of...
swapping a grand cherokee rearend for a cherokee dana 44 is it strait bolt in kojak70 ZJ Grand Cherokee Forum 2 11-01-2009 11:44 PM
Will A 242 Transfer Case From A 90 Cherokee Fit In My 99 Jeep Grand Cherokee.?? squirrly ZJ Grand Cherokee Forum 8 03-05-2009 05:55 PM
Trailer Hitch swap from Cherokee to Grand Cherokee hitchikerjoe ZJ Grand Cherokee Forum 4 09-29-2008 05:02 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
Grand Cherokee vs. Grand Wagoneer exhaust Wiley ZJ Grand Cherokee Forum 2 12-31-2005 07:15 PM
