HELP Just had a miserable 9 hour drive(tranny) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > HELP Just had a miserable 9 hour drive(tranny)
FS: Wranger BRIGHT License Plate LED! Just $3! Great valuePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-04-2013, 08:10 AM   #1
toates89
1989 XJ Cherokee
So i noticed about 6 months ago my GF's 04 4.0l doesnt want shift when it should. mainly when cruising. It will shift and get up to speed but when i start going up hills it wont leave overdrive. i drove across ny state and not once would it leave overdrive going up hills.
I adjusted the kick down cable but it didnt help so i put it back.
any ideas
toates89 is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 08:29 AM   #2
toates89
1989 XJ Cherokee
I adjusting the tv cable because i thought the porblem must be mechanical because there are no codes. no cel and i double checked with the key trick. I am think could it be either the tps, input or output sensor?
also it doesnt shift hard,, or flare in any gears.
Unread 07-04-2013, 09:07 AM   #3
rcwj04
Try pressing the button to disable auto drive
[CENTER][COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Green"][URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #744[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR][/CENTER]
[QUOTE]You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
[/QUOTE]
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
[FONT="Century Gothic"]2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)[/FONT]
rcwj04 is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 09:08 AM   #4
dcocch
Mine did something similar a few years ago. It was the solenoid and sensor in the tranny.
dcocch is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 09:14 AM   #5
rcwj04
In all seriousness the guy above is probably right. Just out of curiosity, did you change the throttle position? I say this because sometimes mine won't kick down unless I'm pushing down far on the throttle, or if I lift up.
[/QUOTE]
Unread 07-09-2013, 10:41 AM   #6
toates89
1989 XJ Cherokee
What solenoid and sensor?
Recently(maybe 6 months) it makes a little whine noise when in nuetral, drive park, and rev are fine. smooth shifting.
If i want it to kick out of overdrive i need to go to near WOT.
Unread 07-09-2013, 11:00 AM   #7
elcorvino
2003 WJ
Same here.
elcorvino is offline   Reply With Quote Quick reply to this message
Unread 07-09-2013, 01:33 PM   #8
toates89
1989 XJ Cherokee
Originally Posted by elcorvino View Post
Same here.
What sensor, and solenoid?
Governor, and Overdrive?
When you had problems did it feel slow because it just wouldnt down shift? thats the main problem.
Unread 07-09-2013, 01:50 PM   #9
elcorvino
2003 WJ
I have my repair list back home and won't be there for a few days. This was 2 years ago, but from what I recall, the jeep was slow as dirt and did not shift right. Felt like my tranny was toast. Either solenoid or sensor, said it was bad from the ring breaking apart and sticking to it (because it is a magnet and that was screwing it up some how). Dude told me I needed a tranny rebuild - could be pulling out of his shop or a year from then. Has been 2+ years now... I just try not to do rev drops and beat on it. Lol
Unread 07-09-2013, 01:58 PM   #10
elcorvino
2003 WJ
I have these 3 issues that I resolved saved to my note pad.
PO601 - internal control module
PCM - governor pressure sensor
P1762
Don't recall which it was or if it was either of those. My main computer above the passenger went bad and that's what I thought the issue was, but it was in fact a solenoid or something in the tranny. Cost me 2 and change to have the shop do it.
Unread 07-09-2013, 02:30 PM   #11
toates89
1989 XJ Cherokee
Wouldnt i have a code thou?
Unread 07-09-2013, 07:18 PM   #12
elcorvino
2003 WJ
I would think - I'm not an expert on this matter.
Unread 07-14-2013, 05:15 PM   #13
elcorvino
2003 WJ
Got home and checked. I had to have my governor pressure sensor valve and solenoid replaced. I was indeed throwing a code.
Unread 07-17-2013, 10:29 AM   #14
toates89
1989 XJ Cherokee
maybe a code will eventually show up.
