help jeep misfiring! - JeepForum.com
post #1 of 4 Old 09-16-2013, 07:31 PM Thread Starter
kharney
2003 WJ
So my jeep was running rough, 03 4.7 130 k on it and I was thinking maybe it was just a bad batch of gas because I just filled up this morning then it got worse and now I'm throwing a p0302 cylinder 2 misfire idk what to do my plugs are recent maybe 10 k ago replaces with champion platinum I believe.. And advice? Do you think that it could be a bad tank of gas?
2003 4.7 quadratrac II 120k bone stock for now :)
Dana 30/186MM Front Axle
3.73 Rear Axle Ratio
Dana 44/226MM Rear Axle
kharney is offline
post #2 of 4 Old 09-17-2013, 12:46 AM
doorjamm
Clean your iac. Plenty of threads on that. Also YouTube videos. See if that helps.
There might be a way to do a homemade smoke test to check for a vacuum leak.
Could be a lot of things though, search function on the forum is a huge help in these cases.
doorjamm is offline
post #3 of 4 Old 09-17-2013, 01:58 AM
perfeng702
Double check your plug to make sure it's not fouled. Swap the #2 coil with a coil from another cylinder. Clear your codes. If the code jumps to the cylinder you swapped coils with, your coil could be bad.
1999 WJ 4.7, 242HD, IRO 4" Long Arm, IRO Adj Track Bar, JKS BPE, JKS Quick Disco, 15" Cragar D-Window, 32" BFG KM2, V3 Projectors, DDM Tuning 55w 5k HIDs
perfeng702 is offline
post #4 of 4 Old 09-17-2013, 08:06 AM
oldfamilyguy
have you ever overheated? If its not a spark or fuel issue it can be a loose valve seat, when it happens usually on #2 cylinder
oldfamilyguy is offline
