Help! Fog light removal! - JeepForum.com
post #1 of 15 Old 01-31-2013, 04:08 PM Thread Starter
rloew275
Help! Fog light removal. Any easy way to get to the fog lights? Just rip the plastic out in the fender well??
rloew275 is offline
post #2 of 15 Old 02-01-2013, 04:20 AM
cykaaro
Crawl underneath and look up. If it's bulb replacement, then you should be able to get in there without removing anything. If you're taking the whole housing out, then it's best to turn the wheel so it gives you room, undo the clips that hold the fender well to give you more room, unhook the light wire haress and then using a ratchet unbolt them. They'll just fall out. Be careful not to crank too hard on them Typically the bolt is rusted so the whole thing will unscrew from the housing, but occasionally it can just brake the bolt. If they come out great (doesn't take too much force at all) but if you're finding it needs quite a bit, stop, and hit with PB blaster so you won't break it, let it do it's job, and then try. you can always use a little heat and hit with cold water which works great, but you it mind burn the bumper somewhat so don't really recommend. (in honesty, usually the bot will unscrew from the housing. Only once have I ever had one snap off the head before, but still it can happen.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 15 Old 02-01-2013, 04:28 AM
elcorvino
2003 WJ
As stated above, turn the wheel and come in from the bottom. There is no need to tear out the plastic.
The light housing has 2 bolts holding it in. The light itself just twists out.
elcorvino is offline
post #4 of 15 Old 02-01-2013, 10:00 AM Thread Starter
rloew275
Thanks guy! I was able to get up in there this morning to swap out the bulbs. I was worried that the 9005 bulbs I got wouldn't fit because they weren't the 9005xs with the 90 degree bend and I was afraid they would stick too far out into the wheel well but they fit just fine. Thanks for the input!!
rloew275 is offline
post #5 of 15 Old 02-03-2013, 10:13 AM
cykaaro
Good to hear! Actually the stock bulb type for the foglights are 9055 type which are IMO too low to use effectively. The 9005 bulbs will give a much better light output. Cheers!
cykaaro is offline
post #6 of 15 Old 02-04-2013, 10:29 AM Thread Starter
rloew275
I agree!! 9005 work much better and actually put out much more light!! Here's the comparison from the driver side 9005 and the passenger side 9055
rloew275 is offline
post #7 of 15 Old 02-04-2013, 10:56 AM
cykaaro
Makes a huge difference when there's no streetlights like where I am. Not planning on hitting a deer if I can help it! Presently working on a HID retrofit for the fogs. Slow going, but should work extremely well. Trying to work out how to put in and allow for up/down and side/side adjusting.
cykaaro is offline
post #8 of 15 Old 02-04-2013, 04:35 PM
4Tom
I wouldn't bother fitting hid in fog lamps it makes them unusable on the road with the glare it causes. Plus in fog snow it cause so much reflection that its easier to see with them switch off than on.
I know this as I tried 9005 HID kit 55w 6000k.
9005 halogen bulb much better and useable.
WJ 2001 3.1TD
Tom
4Tom is offline
post #9 of 15 Old 02-04-2013, 05:13 PM
cykaaro
On that I agree. HID's should never be used in a halogen housings. That is not what I'm working on. I'm doing a retrofit, which is using proper projectors. I'm also going with 3000k bulbs.
This is why it doesn't work putting and HID bulb in stock halogen housings.
Example of HID in halogen housing. No focus of light or cutoff. Blinds oncoming traffic:
HID's in a halogen projector. Kind of a cutoff but still too much glare towards oncoming traffic:
HID in a HID projector (FX-R projector, which is what I have). Proper cutoff.
cykaaro is offline
post #10 of 15 Old 02-04-2013, 05:43 PM Thread Starter
rloew275
Wow.. Awesome comparison. Everyone goes nuts on those who want to throw some hids in halogen reflector housings, but actually seeing the difference supplies proof to everyone's argument.
rloew275 is offline
post #11 of 15 Old 02-04-2013, 06:07 PM
cykaaro
If you google hid in the different housing types, there's tons of examples of each. Those are just at random. You can see why in halogen housings, not only is the glare bad, but they don't put light where you need it. On the road.
cykaaro is offline
post #12 of 15 Old 02-06-2013, 01:37 PM
4Tom
I retro fitted projector lenses in stock headlamps as there is plenty of space and work great with HID bulbs.
But I didn't see projectors lenses small enough to fit in fog lamps.
I did however see projector fogs looks like they use the halogen H1 bulb but the quality seemed questionable from the pictures I seen on ebay. No idea how well they work with HID.
WJ 2001 3.1TD
Tom
4Tom is offline
post #13 of 15 Old 02-06-2013, 06:33 PM
cykaaro
Talked to Andrew at retrofit source. Gave me some ideas to try. Many use the blazer projectors for fogs, (there seems only a handful that work well with HID's as the fogs are different then typical halogen projectors) but I really don't like them at all. And yes, that's the biggest problem. Find a good small sealed projector that works good with an HID bulb. What I'm using fits almost perfectly. I'm working on trimming it for initial fit and cut the back bulb location on the stock housings so far. (been slow at doing it unfortunately) but next is how to put them into a permanent position for maximum adjustablility, and then finish hacking and painting the housing so it all plays nice. Have 3000k bulbs on the way, as I decided to try them over doing the 4300k. Wouldn't go any higer for fogs at all. I have serveral sets of ballasts kicking around, so no problems there. Just have to make up a wiring harness for them.
Once I get this thing more together I'll post up. (or check out my thread on hidplanet)
cykaaro is offline
post #14 of 15 Old 02-07-2013, 12:06 AM Thread Starter
rloew275
Yes, please keep us updated!!!
rloew275 is offline
post #15 of 15 Old 02-07-2013, 02:13 AM
cykaaro
Will do. Going to try to get the mechanics of them worked out this weekend.
The only thing I've ever seen for aftermarket fogs are LEDs which I don't think are good enough output wise, and the halo/halogen projectors which look to ricey. I have a few ideas, but want them to look fairly stock like.
cykaaro is offline
