Help - engine install (ugh) - JeepForum.com
post #1 of 6 Old 05-13-2013, 06:10 AM Thread Starter
MiniCwik
Wj Help - engine install (ugh)
I am hoping for some assistance, installed rebuilt 4.0 engine over the course of the past few weekends into a 2000 WJ Laredo. I have some issues;
  1. 2 - 2 prong female connectors from wiring harness
  2. 1 - vacuum line on back side of intake manifold
  3. No crank, as soon as I turn key over everything turns off (and the tach and speedo guages do some weird rotation
  4. What plugs into the pictured A/C line?
  5. Message on OHD "open circuit"
  6. Where exactly does the crankshaft position sensor go?
I am very excited to get this Jeep rolling again, and appreciate any assistance, thank you!
IMG-20130512-01133.jpg   IMG-20130512-01134.jpg   IMG-20130512-01135.jpg   IMG-20130512-01139.jpg   IMG-20130512-01138.jpg
MiniCwik is offline
post #2 of 6 Old 05-13-2013, 07:37 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You need the crank sensor installed to try and start it... Did it not have a motor when you got the jeep? Did you not label where everything goes?
Crank sensor is on drivers side of the transmission bell housing by the block.
ratmonkey is offline
post #3 of 6 Old 05-15-2013, 01:38 PM Thread Starter
MiniCwik
Thanks ratmonkey, this was an engine swap ... I did not label all of the plugs (learning experience for sure). I will look to getting that installed/connected before the next crank. I have read this is easier accessed from underneath the carpet so will try that out.
MiniCwik is offline
post #4 of 6 Old 05-15-2013, 01:50 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
under the carpet? there's no way to get to it from inside the cab. shouldn't be hard to reach from under the vehicle.
post #5 of 6 Old 05-15-2013, 04:03 PM
99WJ539918
CKP is easy enough. Did you figure out what plugs go where? That shouldn't be too hard. The guages moving up and down indicates a dead/weak battery. Try charging it before you get everything done.
99WJ539918 is offline
post #6 of 6 Old 05-21-2013, 10:22 AM Thread Starter
MiniCwik
Thanks 99WJ and ratmonkey, I was in Columbus for RoTR all weekend and will be getting back at the Jeep this weekend.
I have read on other links that you can access the CKP from behind the carpet under the pedals since it is at the bellhousing, can anyone confirm if this is or is not true?
I know from what I bought that I could not see the sensor easily the last time I checked around for it.
I have also been reviewing the FSM on these left over plug connections but am unsure, as one looks like it would plug into the A/C line but is about a good foot short ... must have a similar plug plugged into something that it shouldn't be and then this one is supposed to go there.
Any ideas on what the vaccuum line on the back of the intake manifold is supposed to connect to?
MiniCwik is offline
