help 24 mpg to 9 mpg - JeepForum.com
post #1 of 4 Old 09-16-2013, 08:42 AM Thread Starter
LIMITEDwoLIMITS
2003 WJ
So i have an 03 with a 4.7 with my 2 inch lift i did new plugs fuel filter all new bushing tres alignment cleaned the tb and sensors and i was getting 24mpgs. At my last command i did upper and lower arms and trac bar. Motor and trans mounts rotors brakes and went up to 255/75/17 on moabs and i dropped down to 9 mpgs. I tried running bp premium and a cleaner and i still only get 9. Any ideas?
03 WJ 4.7 4X4 SWAPPED IRO 4" synergyballjoints,bilstein5100,Addco rearsway,JKS discos
LIMITEDwoLIMITS is offline
post #2 of 4 Old 09-16-2013, 09:19 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Brakes are probably dragging. But don't expect any better than 15 mpg with a lift and 32s.
Also, if you are using the overhead console for MPG, don't. They can be as inaccurate as 50% off, mine is about 30% off and I'm on stock tires.
~Richard
billzcat1 is offline
post #3 of 4 Old 09-16-2013, 09:26 AM
alfaitalia
Not trying to cause are argument but I doubt you ever got that MPG.....more than Jeep claimed for it when new even for a standard vehicle! As Billz said you need to tank full to tank full measure to get accurate results.......maybe your EVIC has suddenly got accurate!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #4 of 4 Old 09-16-2013, 11:32 AM Thread Starter
LIMITEDwoLIMITS
2003 WJ
Ill have to check next time i fill then. When i was stationed in ms i ran 18-24 and when i got to VA i run 9-12
