Heater problems - JeepForum.com
post #1 of 6 Old 09-19-2011, 02:48 AM Thread Starter
foxy1305
Heater problems
I am hoping someone has a solution. My heater air con is working fine on manual and auto. However I cant get any air out of any of the ducts, other than a trickle. The fan runs fine at all sppeds and reacts to a change in temperature but moving the air outlet dial makes no diffrence as to where the air comes out. I hear noises from the dash as though the flaps etc are moving but nothing. Has anyone expierienced the same?
foxy1305 is offline
post #2 of 6 Old 09-20-2011, 05:28 AM
dutch724
If the air is coming out the defroster on the dash then you have a vacuum leak. If it is not doing that, then you have the normal blending door issue. which means you need to pull the dash to fix all the doors in your HVAC system.
dutch724 is offline
post #3 of 6 Old 09-20-2011, 07:50 AM Thread Starter
foxy1305
Thumbs down
Just a mild flow from all areas irrespective of control positioning, so assume the latter. Time consuming I am sure but is it an expensive repair?
foxy1305 is offline
post #4 of 6 Old 09-20-2011, 08:03 AM
dutch724
I have heard the cost is between $800 and $1200 and it takes about 8 hrs to do the job.
dutch724 is offline
post #5 of 6 Old 09-20-2011, 08:21 AM
BigD_44
^^^^thats assuming your dealer does it for you, it's a fraction of the cost to DIY
it's not that expensive to fix, it'll just take you a full day of pulling the dash
http://www.wjjeeps.com/hvac_sub_assembly.htm has all the parts and a good outline of how to go about it
BigD_44 is offline
post #6 of 6 Old 09-20-2011, 09:04 AM
HondaPeople
It does cost that much--because of the labor involved. I'm about to drop that kind of money on my Jeep to have the heater core replaced.
2011 Dodge RAM 1500-HEMI, 2001 WJ Laredo-V8
2008 Honda Recon ES 4x4, 2006 Honda Lawn Mower, 2001 Honda VFR800
HondaPeople is offline
AC/Heater Problems...dr side cold passenger side hot and vice versa jared07 WJ Grand Cherokee Forum 10 03-01-2016 11:18 PM
WJ Electrical Problems with Instrument Cluster, Windows, Heater, EVIC, Alarm and more lewisc WJ Grand Cherokee Forum 6 01-26-2016 11:21 AM
Problems with the heater Epezi WJ Grand Cherokee Forum 9 01-24-2011 01:58 AM
2001 grand cherokee limited heater problems royboy2012 WJ Grand Cherokee Forum 1 12-20-2010 04:39 PM
O2 sensor heater problems greyfox WJ Grand Cherokee Forum 12 08-08-2010 07:33 PM
