Heated seat recall- anyone have experience with this? - Page 2 - JeepForum.com
post #16 of 38 Old 02-02-2009, 07:45 PM
compcrasher86
Talk about pain? I dont even have heated seats! I freeze my butt off in the morning!
Matt
compcrasher86 is offline
post #17 of 38 Old 02-23-2010, 10:39 AM
jayzee503
I took my Jeep in for the heated seat recall in 2008. They replaced the driver's side, but said the passenger's side was fine. This morning I opened the door and the whole passenger side of my truck and the entire roof had caught on fire from the seat!!! Thanks a lot Jeep!
jayzee503 is offline
post #18 of 38 Old 02-23-2010, 11:59 AM
04gclimited
i had mine replaced under the recall just last month. my driver seat didnt work before. but now after they fixed it it works awesome. i guess i cant compare to before because they didnt work, but i did notice they didnt clean up their mess. foam all over the floor.
04gclimited is offline
post #19 of 38 Old 02-23-2010, 12:53 PM
newfieZJ
With safety recalls , they should fix them reguardless if there is an issue or not , recalls are to prevent others from having issues because of factory defects . EX: Toyota is recalling millions , 99.9% of them never had an issue .
You should lawyer up on this one !
newfieZJ is offline
post #20 of 38 Old 05-13-2010, 09:00 AM
Secesh
My wife had the recall done when it came out. Now she's getting notices of a recall on the recall. What did they screw up? We're wondering if it's a problem to worry about now that the warmer weather is here. Can it wait until fall?
Secesh is offline
post #21 of 38 Old 05-13-2010, 02:26 PM
straty1987
it can wait but if you have the time to drop it off and get it done get it done. because when you want it it they might go out.
the recall is due to some people get a extremely warm sensation and they the elements stop working
straty1987 is offline
post #22 of 38 Old 02-19-2013, 12:18 PM
mikehe
i recently had the 2nd recall done on my 2004 grand cherokee. the first recall was a complete success but after the 2nd recall the seat heaters do not put out any heat on low and on high the heaters are hot in the center and cold on the edges of the seat. the bottom line is the fix is totally unacceptable. i recommend not getting the recall done.
mikehe is offline
post #23 of 38 Old 02-19-2013, 12:30 PM
Schlotzky
2007 XK Commander
Next time take a look at the date when you post in a thread, this one has been inactive for nearly 3 years.
That said, my Jeep had the recall done as well, and Low is virtually inoperable, and High is about what Low ought to be. My last car's seat heaters were about 10x more effective.
Schlotzky is offline
post #24 of 38 Old 02-19-2013, 11:24 PM
Jeeples
Jeeples's Avatar
Eh, probably better than starting a new one, plus with all the activity it had, it will most likely show up in a forum search easier.
However, I have to agree with both of you. It really seems they neutered the heat output of the drivers seat with the latest recall 'fix'.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #25 of 38 Old 06-20-2013, 04:06 PM
fastrr
I had my recall done yesterday on my recently purchased WJ. I can not tell if the seats are heating up or not. Granted it is warm out but the previous heaters worked great. I am thinking that either the dealer screwed something up or the things barely put out any heat.
fastrr is offline
post #26 of 38 Old 06-20-2013, 05:53 PM
lazyWJ
2006 XK Commander
I've heard that the heaters they install on the recall are barely noticeable on low. You should feel it on high though, on a hot day it should give you sweaty balls and be a little uncomfortable.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #27 of 38 Old 06-20-2013, 07:39 PM
fastrr
Well I went it sat in both seats with the heater on high for about five minutes. The drivers seat I felt no heat on the bottom or backrest. The passenger I felt heat on the backrest only. I looked under my drivers seat and there is two connectors not connected to anything. The passenger I could see as well. The dealer I took it to is pretty bad and this reconfirms this. It seems that the dealer didn't do the recall incorrectly. Service is crap!
2004 WJ Overland - Just as about stock as you can be for the moment.
fastrr is offline
post #28 of 38 Old 10-13-2013, 06:47 PM
higshemi
Hey guys, my 03 passenger side seat almost caught fire yesterday. Smelt something burning, didn't know if it was coming from car in front of me or what. Out of the corner of my eye I saw smoke rising from underneath my jacket that was sitting on pass seat. Did some searching and found out about the recall. My question is, will the dealership replace my leather from the burn mark? And if so, think I could talk them into replacing drivers side leather as well. Not that my leather is overly worn, but I just think its gonna look silly with an old and new seat cover.
Fred
higshemi is offline
post #29 of 38 Old 10-13-2013, 07:12 PM
bmandubj10
2003 WJ
I waited till mine stopped working. Took mine to Whitten Brothers Jeep in Ashland Va. They did and good job and work great! I have no complaints.
- 2003 WJ Limited 4.7L 4x4, 3 inch IRO coil lift with Bilstein shocks, OME .5 inch spacers, adjustable IRO Track Bar. Beefy Tenneco Steering Stabilizer. 32 inch General Grabber AT2's, 5000k DDM Tuning HID lights. Magna Flow Cat-back exhaust system. Rola safari rack. IRO bump stops. Kevin's Offroad 2 1/4 A-Arm spacer.
bmandubj10 is offline
post #30 of 38 Old 10-13-2013, 07:20 PM
braddf
A lot of people complaining about their jeeps catching on fire. All only posted once in this thread and none in any other thread. Interesting.
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
new heated seat recall. had it done today. ronsaun ZJ Grand Cherokee Forum 19 12-01-2011 10:57 PM
2004 WJ Heated Seats Recall Crookster777 ZJ Grand Cherokee Forum 7 10-27-2006 10:25 PM
Have your heated seats caught fire? JGC Recall micifus ZJ Grand Cherokee Forum 1 06-12-2006 08:42 PM
Heated Seat went out... blueheelers ZJ Grand Cherokee Forum 4 04-12-2005 03:31 PM
Heated seat HELP diverd ZJ Grand Cherokee Forum 7 01-19-2005 04:17 PM
