Heated seat problems - JeepForum.com
post #1 of 7 Old 03-23-2012, 01:16 PM Thread Starter
Fiosman
2012 KK Liberty
Now that we are getting into spring (well we already are),my heated seats aren't exactly working. On the driver side the heated seat doest work at all (no lights on switch *need to confirm that), on the passenger side, it only works on low. I had the truck into Jeep about 4 months ago and they said they didn't want to mess with it. Is this a quick fuse change or switch replacement?
Fiosman is offline
post #2 of 7 Old 03-23-2012, 04:17 PM
4Tom
Driver side is heating element
Passenger switch.
Now before you run out and buy parts you need to confirm these using a multi meter. As I'm working on probability
WJ 2001 3.1TD
Tom
4Tom is offline
post #3 of 7 Old 03-23-2012, 05:06 PM Thread Starter
Fiosman
2012 KK Liberty
How do I use the multimeter to check
Fiosman is offline
post #4 of 7 Old 03-23-2012, 07:23 PM
HVACNY
2013 WK
Using a digital ohmmeter, check the resistance across the four way heated seat feed connector under the seat. The resistance between terminals “A” and “B” should be 0.90 ohms to 1.90 ohms. If the resistance value falls outside of this range, perform the Repair Procedure. From wjjeeps
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #5 of 7 Old 03-26-2012, 07:14 PM
Jeepsake
Before spending any $$, you may also want to check to see if you're covered by the heated seat element recalls - I believe there are two with one superseding the other. Mine were working fine but they replaced them on my 2004 anyway via recall just a couple months ago. Check the Jeep site under "Owners" for recalls affecting your particular rig.
Jeepsake is offline
post #6 of 7 Old 03-26-2012, 07:46 PM
FrnchDp
FrnchDp's Avatar
I'm just going to tag along to this thread and see what ideas are thrown out there. My heated seat issue lies with the driver seat only - it just keeps on heating hotter and hotter.. to the point of too hot. And that's with the setting on low.
I checked for recalls, but doesn't seem like '00s are covered..
1986 CJ-7 - I6-258
2000 WJ Limited - V8-287
FrnchDp is offline
post #7 of 7 Old 03-27-2012, 05:12 PM Thread Starter
Fiosman
2012 KK Liberty
Maybe the switch
Fiosman is offline
Heated Seat = Burned A**!! chrisf695 WJ Grand Cherokee Forum 9 02-03-2012 03:37 PM
heated seat parts (261.6$ vs 46.5$) biglizheng WJ Grand Cherokee Forum 7 01-08-2011 09:37 PM
Heated Seat Problem TORMULA WJ Grand Cherokee Forum 5 01-06-2011 08:30 AM
heated seat parts (261.6$ vs 46.5$) biglizheng WJ Grand Cherokee Forum 0 12-15-2010 02:33 PM
Heated Seat Driver Side problems theskier74 WJ Grand Cherokee Forum 6 12-09-2010 09:16 PM
