the heat kills my jeep - JeepForum.com
post #1 of 3 Old 08-30-2013, 07:20 AM Thread Starter
Jameswj4
So ive had trouble in the past with the main wiring harness that wraps around the back of the valve cover with the stud back there so I wraped the harness back up with tape and covered up the stud..
Now to the other problem. Its only happened twice but when ever it gets really hot like 95+ degrees and I drive for quite a bit she starts stalling and whenever I get her running again it idles really low and bad.. and if I try to give it gas it does nothing. .. now I got a codes for a cyl 4 misfire. And evap leaks.. does that have anything to do with it??. I thought that the heat may have mealted wires
'04 WJ "Sherry" 4.0L RCX 4in lift on 265/75/16 BFG ATs DD/Trail rig- uniden 505xl 4ft firestik- custom roof Rack- custom rear and front shackle tabs-
Jameswj4 is offline
post #2 of 3 Old 08-30-2013, 08:55 AM
99WJ539918
Check the spark plug, injector, and coil boot in cylinder #4. The evap leak won't affect how your WJ runs.
Build Thread
99WJ539918 is offline
post #3 of 3 Old 08-30-2013, 09:26 AM Thread Starter
Jameswj4
Alright thanks
Jameswj4 is offline
