Heat/AC Blower works just no air? - Page 3 - JeepForum.com
post #31 of 37 Old 07-10-2013, 03:40 PM
rdkendrick
2003 WJ
Originally Posted by BigRedKM View Post
Im having the exact same problem. Some say if your cruise control doesn't work then its because you have a vaccum leak. But mine works but just no air. I switched the polarity on the plug also but it still had no effect. I also reset the azc system via the fuse and still no luck. My next plan is to take out the motor and see if anything is blocking the passage.
If you have an AZC system, it is electronically controlled, not vacuum. Did you do a search for blend doors? Someone else complained when I gave a link for www.blendorstore.com but I never had a problem with them and it helped me understand everything. Also, heatertreater.com, etc.
SORRY, DIDN'T LOOK AT THE DATES.
Sent from my iPad using Forum Runner
rdkendrick is offline
post #32 of 37 Old 07-10-2013, 03:42 PM
rdkendrick
2003 WJ
Originally Posted by bjm9818 View Post
My issue was I replaced the motor controller 8 mOnths ago and installed the redesigned part. The fan worked but as I stated above no air came out. I even ordered s new controller and same thing. My only option was to use the old controller with the new harness plugged into the three pins sticking up from the board and put it back that way.
It has worked fine since then but last week one of the pubs broke off the board so that's when I decided to try the new part. I even went to the dealership yesterday to see if there was a different part but he came up with the same thing.
My blend doors and Recirculator door were replaced a few years ago so I'm pretty sure that's not the issue.
If you are pulling error codes 52& 54, you definitely have blend door problems. i believe those errors mean door travel too large, which means the blend door is not moving.
post #33 of 37 Old 07-10-2013, 03:49 PM
rdkendrick
2003 WJ
Originally Posted by MelRock View Post
Any updates on the fix for this? I am having the same problem. I can change from heat to cool, I can hear the fan running but not a whole lot of air coming through the vents up top.
I am working on a 2003 Jeep Grand Cherokee.
Did you put the new blower resistor kit on it? If so, from what other posters have said, the new kit has a heat sink with prongs that are longer than the original. If you have that, reverse the black and red wires. It will make the fan run faster. See recent threads concerning this.
post #34 of 37 Old 07-11-2013, 07:36 AM
MelRock
Yes I did put the new resistor kit on and that is when the air stopped flowing full speed through the vent.
Thank you and I will give that a try today.
MelRock is offline
post #35 of 37 Old 07-12-2013, 07:14 PM
MelRock
Thanks again and that did get the fan blowing more air. My problem now is that the motor will not turn off. Any help anyone can give me would be appreciated.
MelRock is offline
post #36 of 37 Old 07-15-2013, 08:25 PM
rdkendrick
2003 WJ
Did Narnwv help you any? I was watching a YouTube video:
http://youtu.be/2vmfxYg8LoY and was thinking it could be your relay.
post #37 of 37 Old 07-16-2013, 02:43 PM
MelRock
Did Narnwv help you any? I was watching a YouTube video: and was thinking it could be your relay.
I found out the problem. I was switching the wrong motor wires or should I say the wires on the wrong side of the resistor. Everyone talked about the red and black wires and the only red and black wires I had went back to the battery. The wires that went back to the motor are green and black on my resistor. I switched those out and it works perfect now.
Thanks for your help!!
MelRock is offline
99 grand cherokee insalled blower motor resister & blower working please help latenite1999 WJ Grand Cherokee Forum 5 01-05-2014 07:43 PM
drivers side AC/heat works great, passenger only cold air Pepsishine WJ Grand Cherokee Forum 4 03-02-2011 09:04 PM
code 52, heat kinda of works raygoodson2006 WJ Grand Cherokee Forum 10 12-14-2010 09:09 AM
2003 WJ ac / heat blower sams WJ Grand Cherokee Forum 2 08-04-2010 07:26 PM
A/C works on and off baden WJ Grand Cherokee Forum 1 03-31-2010 04:18 PM
