Headlights turning off and on by themselves - Page 2 - JeepForum.com
post #16 of 22 Old 11-12-2013, 08:16 AM
kpurintun
Any word on an actual fix on this problem? Not using Auto requires an 8yr habit change (with the jeep alone). This is something that has not been a part of my conscience for my entire life behind the wheel. its obviously something triggering the relay.
I doubt its the ignition cylinder because it does the same thing while driving and off. I would bet a banana that its the light sensor. does anyone know where this is?
Kyle
kpurintun is offline
post #17 of 22 Old 11-12-2013, 08:32 AM
Jrboarder27
On mine I think its part of the red led blinker for the security system (if that's what you want to call it) in front of the dash. If you look at it through the wind shield there is a silver peice.
Sent from my Galaxy S4 using JeepForum
Jrboarder27 is offline
post #18 of 22 Old 11-12-2013, 09:34 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Kyle
There's a thousand threads since this one (from 2011) that discuss the problem. It's the turn signal stalk. It's very common. Replace the stalk with one with your same options, ie auto lights and fogs, and your problem will be solved.
~James
ezflip is online now
post #19 of 22 Old 11-13-2013, 09:58 AM
kpurintun
aah... my Jeep is sad... its like an old man with 18 serious simultaneous expensive issues.. like an intermittent evap issue, intermittent misfire and potential coolant leak in cyl 3, a coolant smell inside the car, a loose transfer case chain, rough idle, ripped seat leather, needs new shocks, new battery, and tires.. power steering whines a bit, and this headlight/stalk issue.
thanks for the update. if i find $80 sitting around... ill fix it.
post #20 of 22 Old 12-02-2013, 08:29 PM
JimHern
Possessed Headlights
I do NOT have "auto" light option and mine are turning on and off randomly as well! I am going out to disconnect my new battery (to save it) that I just bought today. Even dealer witnessed the random light show with no explanation. Taking it back tomorrow for further diagnostics!
JimHern is offline
post #21 of 22 Old 09-30-2015, 03:09 PM
dianageisel
Jim,
Did you find what the problem was with your headlights? I am having the same issue.
dianageisel is offline
post #22 of 22 Old 09-03-2017, 09:35 AM
Sharon62
Angry headlights turning off and on by themselves
My 2008 Liberty is doing the same thing, but my door locks are also locking and unlocking when the headlights do their trick! I, too, just bought a new battery. I am afraid the Dealer is next to do diagnostics. $$$$$$
Sharon62 is offline
WJ Limited headlights for Laredo or any black out headlights. MrJayDeeM WJ Grand Cherokee Forum 34 03-23-2012 09:00 PM
popping when turning DrGrebo WJ Grand Cherokee Forum 5 08-29-2010 01:47 PM
Headlights turning themself on jjfrieze WJ Grand Cherokee Forum 2 07-23-2010 04:52 PM
99 GC Stalls turning when low on gas viper1993 WJ Grand Cherokee Forum 6 02-24-2004 10:59 AM
Turning in a Lease. mg5454 WJ Grand Cherokee Forum 0 08-09-2002 11:43 AM
