Headlights - JeepForum.com
post #1 of 11 Old 10-21-2010, 10:30 AM Thread Starter
akaplaya0234
Wj Headlights
Hey guys,
I have a 99 WJ laredo and I recently put h.i.d.s in them and now my signal lights are acting up. The right side lights flash kind of light cop cars do and the left side only one bulb flashes. Do you guys have any idea of what it possibly could be?
akaplaya0234 is offline
post #2 of 11 Old 10-21-2010, 02:29 PM
Skytard
Wired wrong??
Poor college student.
Skytard is offline
post #3 of 11 Old 10-21-2010, 03:17 PM
compcrasher86
where did you ground your HID kits to? They should have a separate ground from the other bulbs dont just plug them into the old headlight sockets and call it a day. HIDs are nowhere near plug and play.
PS if you treated them like plug n' play and just threw them in place of the original bulbs in factory housings without upgrading to projectors you need to fix that quickly and quietly
Matt
compcrasher86 is offline
post #4 of 11 Old 10-21-2010, 05:30 PM
99WJNM
no tell us did you did you....................................... J/P i am looking to upgrade to hid's and would love info on how this done
99WJNM is offline
post #5 of 11 Old 10-21-2010, 06:05 PM
compcrasher86
Lol well I told him to fix it quietly because people on here will flame you to hell for running HIDs in a housing meant for projectors. Realistically, you have to get a projector housing for the WJ which means either hacking apart the factory housings and mounting a DOT approved projector or getting aftermarket ones designed for HIDs
Matt
post #6 of 11 Old 10-22-2010, 11:20 AM
Amerce
i run 6k HIDS that i bought from ebay for 40 dollars, they came with ballasts and are basically plug and play with a few extra plugs, i have halo projector housings and no ones complained and have not gotten pulled over.
Amerce is offline
post #7 of 11 Old 10-22-2010, 11:31 AM
GregC6
I am also running the plug n play 6k kit
pull the headlights out, plug them in, put headlight back in and they work
I got my from DDM tuning $25+shipping
HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
they ship slow, but can't beat the price
GregC6 is offline
post #8 of 11 Old 10-22-2010, 11:51 AM Thread Starter
akaplaya0234
Well they are plug and play ones literally. Its the same shown above from ddm tuning, i just happened to get mines from another vendor. I didn't have to disconnect anything except slip the new bulbs into the old socket and I didn't have to rewire anything. And don't worry they are not factory housings, I have some projectors for them.
post #9 of 11 Old 10-22-2010, 11:59 AM
compcrasher86
Im just going to assume you're using aftermarket projector housings GregC. Otherwise you make a great example of the clueless victims to the ebay ads and other Ricer tricks that convince you all you have to do is pull out the old bulbs from the factory housings and put in the new ones. HIDs have a completely different beam pattern and light output style so putting them in your factory housings will reak havoc on other drivers' eyes
OP, good job for doing it the right way. Although I find it unlikely, I know those bulbs share a common ground and I believe the nature of the HID ballasts with their electronic interference and very high voltage can cause the regular incandescent bulbs in the turn signals and park lamps to fail. Thats my best guess
Next step would be testing for voltage at the turn signal bulbs and checking their ground. IF good, replace the bulbs and relocate HID ground to avoid repeat problems
btw ddmtuning ftw
Matt
post #10 of 11 Old 10-22-2010, 12:10 PM Thread Starter
akaplaya0234
how would i test for the voltage? would i use a simple voltage tester/detector?
post #11 of 11 Old 10-22-2010, 12:15 PM
compcrasher86
Yeah, test lights are frowned upon with modern vehicle electronics but people still use 'em anyways so just probe the bulb sockets for voltage. You're looking for something along the lines of 12v. To test ground, its useful to have a multimeter with continuity testing and you test the (-) socket of the bulbs with a good ground, look around the engine bay, youll find some bare metal thatll work
Matt
restored my headlights..... thenewb WJ Grand Cherokee Forum 0 10-04-2010 05:10 PM
WJ HID Aftermarket Headlights W3MOT WJ Grand Cherokee Forum 18 09-20-2010 07:32 PM
Headlights For My WJ?? Relax_Jimmy24 WJ Grand Cherokee Forum 23 08-15-2010 10:03 PM
My first car! 01 WJ! now for my first mod? headlights and HID questions ThePhenom WJ Grand Cherokee Forum 5 08-02-2010 02:04 PM
Headlights WJ mackin0476 WJ Grand Cherokee Forum 15 06-09-2010 07:24 AM
