Headlight bulbs keep fusing - JeepForum.com
post #1 of 4 Old 04-26-2013, 12:53 PM Thread Starter
djwj00
I had changed the headlight bulbs (both) last summer around this time. One has fused again. This is the second time since my owning this 2000 WJ 4.0 that bulbs needed replacing so fast.
Where do I start looking?
djwj00 is offline
post #2 of 4 Old 04-26-2013, 01:24 PM
imaguy3
By "fusing out" do you mean you're blowing fuses... or the bulb itself is burning out?
If it's the bulb, when you replace them make sure you don't actually touch the glass with your bare hands. The oils on your hand get on the glass, which creates hot spots and leads to decreased service life. I usually grab them by the base with a paper towel, and then wipe them again right before putting in the housing.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #3 of 4 Old 04-26-2013, 02:05 PM Thread Starter
djwj00
yes the bulbs.. hmm time to buy new set ughh
djwj00 is offline
post #4 of 4 Old 04-26-2013, 02:21 PM
imaguy3
Also usually the higher the output the lower the life. That's why the long life bulbs last so much longer than the Sylvania Silverstar and the like...
imaguy3 is offline
