Head Gasket? Or something else? - JeepForum.com
post #1 of 8 Old 11-24-2013, 12:29 AM Thread Starter
gr8gonzo0
I have a 2002 4.7L V8 HO Grand Cherokee. While my wife was driving the vehicle, it suddenly started to run very rough and would stall while driving. She noticed smoke from the exhaust (I think it was white). I took a look and the engine light was on with P0203 and P0303 codes. According to my wife, the coolant had been low for a few days and was dry when I looked at it.
I tested the resistance in the fuel injectors and they appear to be working. There appears to be power and spark to the #3 cylinder. The dipstick was not milky and just looked like oil. When I opened the radiator cap, it looked a little like milky oil. I suspect it is a blown head gasket. I do not have a compression or leak down tester. I may go get one or both in the morning. What are your thoughts? I am really tight on funds. If I could only buy one of the testers, which would you recommend?
Thank you.
gr8gonzo0 is offline
post #2 of 8 Old 11-24-2013, 12:53 AM
nolimitssjca
White smoke is a tell-tale sign of a coolant leak.
code P0203 is a fuel injector code. It can be tested by swapping injectors with adjacent cylinder (#1). You may be able to smell unburned fuel if the injector is stuck open.
1999 WJ 4x4, 1997 ZJ 4x4
1997 Mountaineer 4x4, 1996 Explorer 4x4
1972 Mustang Mach 1 351 Cleveland, 1972 Mustang Coupe 302
1970 Chevy C-20 350, 2002 Kawasaki Vulcan
nolimitssjca is offline
post #3 of 8 Old 11-24-2013, 02:43 AM
car5car
2002 M-38
0303 is misfire in cylinder 3,
0203 is fuel injector in cyl 3 mulfunction
Buy compression gauge.
01 XJ 2wd 4.0
car5car is offline
post #4 of 8 Old 11-24-2013, 03:10 PM
PA55
2003 WJ
Get a combustion leak tester
http://www.ebay.co.uk/itm/Block-test...-/181059430832
or take it to someone with an exhaust gas analyser and sniff the radiator coolant for hydrocarbons.
Next best Compression gauge
PA55 is offline
post #5 of 8 Old 11-24-2013, 05:06 PM Thread Starter
gr8gonzo0
Ok. I got a compression tester and the #3 cylinder had 0 psi (needle did not move at all). The adjacent #5 cylinder only had about 65 psi. All the other were above 160 psi. I put some oil in the #3 and #5 cylinders. Nothing changed in the #3, but the #5 went way up (over 250 psi). I am a little confused. I know a low reading on two adjacent cylinders is an indication of a bad head gasket and would also explain the other symptoms, I think. But the increase in the compression after adding oil indicates worn piston rings. Any thoughts?
post #6 of 8 Old 11-25-2013, 12:13 AM
nolimitssjca
0 PSI could be an indication one of the calves is not closing. Could be a valve seat has let loose and is holding it open. If this is the case the rocker arm would be lose enough to get tossed off (good thing). It's pretty easy to pull the driver side valve cover and see if a #3 rocker arm is loose.
post #7 of 8 Old 12-07-2013, 03:50 PM Thread Starter
gr8gonzo0
I decided I would try to pull the heads and see if it is a blown gasket. After I remove the vibration dampner (harmonic balancer) to get to the timing cover, do I need the Special Tool required to install it? It looks like it is hard to find and very expensive. I have found a lot of discussion about getting the thing off, but I want to also make sure I can get it back on. Any help would be much appreciated.
Thanks!
post #8 of 8 Old 12-09-2013, 02:29 AM
nolimitssjca
Start by pulling the valve cover only. The rocker arms will tell you a lot.
