Have 4.0 wj w/ 247 can I swap 242ld - JeepForum.com
post #1 of 1 Old 09-20-2011, 11:06 AM Thread Starter
Dhall09
I own a 2004 WJ with a 4.0 liter and it has a Quadra-trac II nv247. I am planning on installing a locker in the rear axle, but from my understanding if I do so on the full time four wheel drive it will cause the front to bind, if I choose to use an AuSsie locker. I know most choose to use the selec-trac. If I get a 242ld would I have to change drive shafts or modify the transfer case for it to work, or since I have the straight 6 would it be plug and play? If I were to choose an ox locker could I stay with the nv247 or is the performance of selec-trac worth the swap?
Dhall09 is offline
Swap v8 for 6 cyl??????? 73watermutt WJ Grand Cherokee Forum 26 09-26-2014 08:35 AM
4BT swap into WJ mcclintock89 WJ Grand Cherokee Forum 37 06-10-2012 10:26 PM
PCM Swap Macfadden WJ Grand Cherokee Forum 4 05-12-2011 10:31 PM
Swap 4.0L into 4.7L WJ. kingplay334 WJ Grand Cherokee Forum 6 02-24-2011 08:14 PM
4.0L swap jkhjeep WJ Grand Cherokee Forum 4 02-12-2011 02:45 PM
