*** handed to me - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > *** handed to me
1999-2004 Jeep Grand Cherokee Front Wheel Bearing & Hu1993-2004 Jeep Grand Cherokee Steering Damper Trail Boss (50" LED CREE Light Bar Pair With Wiring Kit
Unread 02-23-2015, 10:20 PM   #1
trannyman
*** handed to me
hey guy's i'm getting my lwr unit handed to me i run a transmission shop in bfe i have a 99 jeep grand cherokee has a bad pcm tried to save my customer money by putting a used pcm in it what a cluster f towed it to the dealer for flash they said they couldnt do it ninty bucks later then i was told that there were issues with skim and all kind of crap i learned black key no skim gray key skim i called my buddy at chrysler and gave him vins and he told me which ones have sentry and which ones dont and the ***** will still not run however i havent tried to leave the battery disconnected i was only trying to save my customer money and i'm getting my *** kicked i know it has to be possible or the bone yards woud'nt sell them please help my customer THANKS IN ADVANCE
trannyman is offline   Reply With Quote Quick reply to this message
Unread 02-23-2015, 11:36 PM   #2
fiveseven15
if you can get the cluster to power on/give you test lights that'll tell you if it has skim or not look for this. if it has this, its got SKIM, and i think that has to be programmed separately
next to the cruise light. differnt location for a WJ but it looks like that
fiveseven15 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2015, 09:34 AM   #3
username00
Oh man, you just reminded me why I don't pay people to work on my vehicles.
username00 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2015, 04:42 PM   #4
xxturbowesxx
There's some punctuation.
Apply where needed.
xxturbowesxx is offline   Reply With Quote Quick reply to this message
Unread 02-24-2015, 05:05 PM   #5
oldRodney
It never fails....by trying to save someone a few dollars, you have turned their problem into your problem.....
tow it back to your shop.
put the original pcm back in. return the used one to the wrecking yard.
tow it back to the dealer..
let them take over...
oldRodney is offline   Reply With Quote Quick reply to this message
Unread 02-25-2015, 07:13 PM   #6
03aggieWJ
Good call on that one my dad and I have a repair shop. I can program ford and gm stuff all day long no problem. When the pcm on my WJ decided to die and leave the alternator not charging I looked into all the options said screw it and took it to a dealer. Wish I had dodge stuff we just don't get enough of them through the door to justify buying the programming equipment and access to flash information for them. Mine cost 983.64 for new pcm and all necessary reflash mine has sentry keys also. The old day's of swapping modules to verify problems or salvage yard stuff are quickly coming to a close with modern technology.
03aggieWJ is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 09:42 PM   #7
Jameswj2001
The 99 you're working on likely doesnt have skim. The pcm you're trying to swap in likely does have skim and it's been activated. Once skim has been activated in the pcm, you cannot use it in a non skim'd system. The dealer cannot turn off/erase skim from the pcm. HOWEVER, it can be done. The are several companies who will erase skim from the new pcm so that it will function in the non skim'd 99.
01 WJ 4.7 quadra drive 2" bb 245/70/17 grabber at2's
00 XJ 3" lift Wrangler authority 31 10.5 15
Jameswj2001 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 11:22 AM   #8
Inferno451
Don't all WJ's have SKIM? My 99' does...
Inferno451 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 12:04 PM   #9
alfaitalia
CRD Pilot!
alfaitalia's Avatar
It's very rare but a few of the earliest production 99 wj models did NOT have skim. Their keys look slightly different too. I did not know it either until a couple of members on here with very early models showed me otherwise.
Sent from my SM-T310 using JeepForum
Going to war over religion is like killing someone because your imaginary friend is better than theirs!
alfaitalia is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 07:19 PM   #10
99WJ539918
Mine does not have a SKIM. There are some out there.
99WJ539918 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 07:34 PM   #11
js12278
No SKIM on mine either, 99.
js12278 is offline   Reply With Quote Quick reply to this message
Unread 03-01-2015, 09:20 AM   #12
Jeeples
Jeeples's Avatar
SKIM wasn't a standard feature until '00 IIRC.
His: '00 WJ 4.7 Limited- stock
Hers: '03 WJ 4.7 V8- IRO 3", 245/75/16 Duratracs
Jeeples is offline   Reply With Quote Quick reply to this message
Unread 03-04-2015, 12:14 PM   #13
oldRodney
The original poster TRANNYMAN, hasn't had anything to say in over two weeks......
Hopefully, he got his lower unit re-attatched and his a** is all healed up...
too bad, cuz I wanted to see how it all turned out...
Unread 03-04-2015, 01:11 PM   #14
Satrebil
OP, pipe in here if you would.
01 WJ Limited Inferno Red 4.0L Selec-Trac
04 WJ Limited Inferno Red 4.7L Quadra-Drive
Satrebil is offline   Reply With Quote Quick reply to this message
