Guys PLEASE HELP! 2.7 overland. - JeepForum.com
post #1 of 24 Old 11-23-2013, 04:38 AM Thread Starter
Longdayslongnig
Unhappy Guys PLEASE HELP! 2.7 overland.
Guys, I'm new here so sorry if this has all been covered I got a few problems! My jeep appears to be dying :'(
Firstly my steering.... Christ... It's so stiff!!! It's like my jeep is a tank with manual steering..... It's drivable but it's a mission to turn the wheel. It's had a new pump which made it better for few days now it's back to square one.
2nd my fans are just pumping out cold air??? Read online this could be blend doors???
Also had a fuel leak and the engine is just covered in diesel! Pipes have been replaced so hope that's sorted! Just feel like my jeep is dead!
Longdayslongnig is offline
post #2 of 24 Old 11-23-2013, 08:12 AM
PA55
2003 WJ
Hi,
Is your power steering fluid level OK and did you use a Jeep approved fluid?
Is your drive belt slipping ? maybe contaminated with diesel.
Jim
PA55 is offline
post #3 of 24 Old 11-23-2013, 10:18 AM Thread Starter
Longdayslongnig
This is possible, but if the belt was slipping would that make the steering insanely stiff?
post #4 of 24 Old 11-23-2013, 10:23 AM
MuddyWJ
If the belt slips it won't turn the pulley to your pump.
MuddyWJ is offline
post #5 of 24 Old 11-23-2013, 10:32 AM Thread Starter
Longdayslongnig
That's the technical for my noob brain lol.... So yes it would cause the stiff steering? Lol
post #6 of 24 Old 11-23-2013, 10:56 AM
alfaitalia
Jim
Good shout.....that's where my money would be.
Sent from the Dark Side using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #7 of 24 Old 11-23-2013, 11:18 AM Thread Starter
Longdayslongnig
Thanks guys! I shall buy a new drive belt tomorrow and give it a crack! Will report back! Do you all think the blowers could also be linked to this? I noticed on the belt disgram it has a "no a/c" route? So maybe the belt is routed wrong? Or is that just me with wishful thinking?
post #8 of 24 Old 11-23-2013, 01:05 PM
PA55
2003 WJ
It is possible that your belt is routed wrong I've seen it before on other vehicles, causing no end of problems.
the heater is a different matter altogether, It could be
1, thermostat stuck open,
2, heater matrix blocked,
3, blend doors broken,
4, recirculation door broken
any or all of the above
What temperature does your gauge read when the engine is hot?
Jim
PA55 is offline
post #9 of 24 Old 11-23-2013, 02:48 PM Thread Starter
Longdayslongnig
The AA has been out and the guy said they should all be linked... After I drove home from work the jeep was overheating and I noticed my drive belt hanging under my jeep along the road, so I'm now 1000000000% sure you guys are all right and it's my drive belt lol! Apparently one of the bearings have gone that the drive belt goes around. Anyone know what these are called and are the pricey??
Hopefully after I've got drive belt in morning and fitted it, she should be up and running again!
post #10 of 24 Old 11-23-2013, 03:15 PM
CarlJH
2003 WJ
There called idler pullys and tensioner pulleys
CarlJH is offline
post #11 of 24 Old 11-23-2013, 04:29 PM
PA55
2003 WJ
Water pump in there as well.
PA55 is offline
post #12 of 24 Old 11-23-2013, 04:32 PM
MuddyWJ
Make sure to clean up the fuel or it'll just happen again.
MuddyWJ is offline
post #13 of 24 Old 11-24-2013, 06:11 AM Thread Starter
Longdayslongnig
Thanks guys, no where open today to buy a drive belt! Sod's law!
Does anyone have a diagram of the pulleys? I've found pulleys but knowing which one it is that's faulty.... That's another question lol!
I know it has grooves in all the way around, not a smooth pulley. And it's at the top in the middle? Anyone know what pulley this is? And where I can get one?
post #14 of 24 Old 11-24-2013, 07:07 AM
PA55
2003 WJ
Any motor factors should be able to get you one
I think there are 2 smooth pulleys and one ribbed one, you need the ribbed one. No2 on the diagram
PA55 is offline
post #15 of 24 Old 11-24-2013, 07:14 AM
PA55
2003 WJ
Here's one on ebay
http://www.ebay.co.uk/itm/JEEP-GRAND...item485c2b0b27
Last edited by PA55; 11-24-2013 at 07:19 AM. Reason: changed link for a better one
PA55 is offline
