Guinea pig new RC Long Arm kit? - Page 9 - JeepForum.com
post #121 of 504 Old 01-02-2013, 11:11 AM
Jeepers21
I'm very interested in this kit. I was told that it is "inferior" to IRO and Clayton's long arm kits and that parts were not reliable. But the person did not mention in which ways it was "inferior." The only thing I can think of that would be weak might be the X-flex joints??? RC says they are rebuild able which to me sounds like a plus. I know they can be replaced with jonny joints also. I'm really having a hard time believing that this kit is inferior.
I know that RC, in the past had the reputation of being a cheap lift kit and quality was substandard to other higher priced kits. Someone a long time ago told me: "having a rough country lift kit is like sleeping with a fat chick; sure it's fun to ride, but you don't want to be seen with it."
I really think Rough Country has changed over the years. I'm depending on this kit to be a solid lift. I can't afford the IRO or Clayton long arms. I like that the RC kit is complete (rear long arms) where this is another $1000 through IRO.
My plan/hopes were to get the RC kit (minus the springs) and go with some 6" springs from another kit. Any thoughts on if this can be done?
Jeepers21 is offline
post #122 of 504 Old 01-02-2013, 11:15 AM
adavis39
i dont believe the RC arms are adjustable enough to run 6'' springs......as in they are not long enough. I guess you could do it, but RC did not design them for 6'' according to the feed back ive seen
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #123 of 504 Old 01-02-2013, 12:01 PM
Timbo24
I asked a rep on there online chat thing and he told me that they were adjustable to up to 6 inches of lift I would call and ask just to be sure though.
Timbo24 is offline
post #124 of 504 Old 01-02-2013, 12:47 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
The long arms are most definitely long enough for 6". I'm running the kit as is, at 4" and pretty much all of the arms are adjusted all the way in. The uppers on the front radius arms are the only ones that are not threaded all the way in and I still have plenty of room for adjustment on those. All the joints are rebuildable but honestly, they seem beefy enough to last quite awhile. I'm not worried about about the longevity of this kit whatsoever.
~James
ezflip is offline
post #125 of 504 Old 01-02-2013, 01:17 PM
adavis39
thats good to know....i heard from someone running it that they wouldnt really work for 6'' springs....oh well, i wonder why they dont offer them then?
TNJEEPS.COM
BUILD:
adavis39 is offline
post #126 of 504 Old 01-02-2013, 01:48 PM
SKI_VT
I just went and asked the online Chat help (josh)
and they said that it can be used up to 6" lift
He said no higher than 6"
"You people make it sound like Claytons are made from gold and unicorn bones while everyone else uses PVC and spaghetti noodles."
"The Great Turtle Race! -> Iceland vs. Bushwhacker! -> Place your bets!"
SKI_VT is offline
post #127 of 504 Old 01-02-2013, 05:49 PM
Roger005
Is anyone running this setup with IRO coils? I compared the free lengths of the two coils and the IRO coils are over two inches taller than the Rough Country. That is what I am considering doing along with IRO trackbar. I was just wondering what the difference would be, or if the IRO coils will offer more lift height than 4". Any thoughts?
Front IRO= 18.75"
Front RC= 16.18"
Roger005 is offline
post #128 of 504 Old 01-02-2013, 05:54 PM
narnwv
narnwv's Avatar
Front IRO= 18.75"
Front RC= 16.18"
What lift height are your coils supposed to be? Free length doesn't matter without spring rate. If the IRO coils are softer than RC's (probably), then they'll compress further with weight on them.
~Aaron
narnwv is offline
post #129 of 504 Old 01-02-2013, 06:07 PM
Jeepers21
Good to know on the 6". Thanks guys. I was looking at the IRO critical path kit, and (don't bash me) from the pictures, it didn't look like the arms were any different from the 4" kit to the 6" kit. Just the springs.
I'm really starting to lean more towards the RC kit. When i have the coin saved up, I think I'm going to have to get it. Did anyone use their JF discount when they bought it from RC?
post #130 of 504 Old 01-02-2013, 07:25 PM
oaklyjeep10
I'm running this kit w RC 4" and 2" bb. I'm wanting to put taller springs and trash the spacers, how do I know how much to adjust everything? And what springs would you guys recommend?
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq
oaklyjeep10 is offline
post #131 of 504 Old 01-09-2013, 07:13 AM
cangus
I tried to apply the JF discount and didn't have any luck
cangus is offline
post #132 of 504 Old 01-12-2013, 01:55 PM
MWyatt
Can someone explain the set up in the rear? Why is it the stock "short" a-arm with lower long arms? Doesnt the shorter a-arm limit the long arms on the bottom? Whats the point?
Thanks
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline
post #133 of 504 Old 01-12-2013, 03:23 PM
cangus
Thanks
The RC 4" long arm kit comes with the upper as well.
cangus is offline
post #134 of 504 Old 01-12-2013, 03:28 PM
MWyatt
But the RC rear upper is the same length as the stock a-arm right? It's the same just adjustable compared to long rear uppers like clayton upper arms or the IRO long a-arm. Or am I mistaken?
MWyatt is offline
post #135 of 504 Old 01-12-2013, 05:44 PM
soupy688
Go to the vendors section. And contact bobby from ccor he will give you a jf discount. I'm ordering my long arm kit on Friday. Good luck
2012 Jeep JKU Call of duty MW3 serial # 1526/3500 Bone Stock
soupy688 is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
