Guinea pig new RC Long Arm kit? - Page 6 - JeepForum.com
post #76 of 504 Old 07-15-2012, 07:26 PM
Merc1973
Bump for updates.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #77 of 504 Old 07-18-2012, 10:49 AM
tsneath
So far everything is great haven't done tomuch wheeling yet just playing around in the dry river. Drives nice on road good ride. Maybe this weekend if I make it out to my families farm I'll get some better flex pics.
tsneath is offline
post #78 of 504 Old 07-18-2012, 11:00 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Good to hear!
~James
ezflip is offline
post #79 of 504 Old 07-18-2012, 01:33 PM
oaklyjeep10
Just ordered this kit yesterday!!
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq
oaklyjeep10 is offline
post #80 of 504 Old 07-18-2012, 02:45 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Fantastic! Hope you like it too. Im ordering mine soon. Make sure you post your thoughts in here once you get it.
~James
ezflip is offline
post #81 of 504 Old 07-18-2012, 02:57 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Can someone take a pic showing where the rear uppers mount to the frame vs. where the rear lowers mount to the frame?
One pic that shows both the upper and lower in the same pic would be ideal.
Wheelin98TJ is offline
post #82 of 504 Old 07-18-2012, 03:00 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
It uses an adjustable A-arm similar to IROs. The adjustment is at the axle. The other side mounts in the stock location.
The lowers mount a few inches rear of the tranny cross member. IIRC from the install instructions.
~James
ezflip is offline
post #83 of 504 Old 07-18-2012, 08:36 PM
Wheelin98TJ
JEEP FREAK
Thanks, I also looked at some more pics of the kit.
The rear lowers are considerably longer than the uppers.
I wonder how much pinion angle change there is throughout the suspension travel?
post #84 of 504 Old 07-18-2012, 08:51 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Yeah, they are. It is almost identical to IROs rear setup, though.
~James
ezflip is offline
post #85 of 504 Old 07-23-2012, 03:25 PM
tsneath
Built me a simple truss. Slash skid plate Saturday nothing special but should do the job
tsneath is offline
post #86 of 504 Old 07-29-2012, 05:21 PM
oaklyjeep10
Just finished the front end of the lift today. Only problem I'm having is my exhaust is rattling on the crossmember. Anyone else had this problem?
post #87 of 504 Old 07-29-2012, 05:25 PM
adavis39
i have a different lift but had this issue with my new TC belly skid I just installed. I just went and got some exhaust wrap and that took care of the rattling..you may need to just check for any sagging in your exhaust though because I would imagine it would be designed to clear the muffler.
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #88 of 504 Old 07-29-2012, 05:45 PM
oaklyjeep10
It's not touching anywhere while sitting still but when I drive it it's obnoxious. I'll get some wrap tomorrow and see if that takes care of it.
post #89 of 504 Old 07-29-2012, 08:23 PM
adavis39
yeah, i had about an 1/8'' clearance. usually sitting it was ok, but any bumps made it rattle like crazy for a few seconds...the wrap did the trick for me though, just kind of a pain to work in there
TNJEEPS.COM
BUILD:
adavis39 is offline
post #90 of 504 Old 07-29-2012, 09:23 PM
tsneath
U just torched it out a bit then ground it smooth mine was doing the same thing but only when I went up to the 3" exhaust
tsneath is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
