Guinea pig new RC Long Arm kit? - Page 5 - JeepForum.com
post #61 of 504 Old 07-06-2012, 11:09 AM
04ovrland
both the WJ and the ZJ long arm kits from RC need to have the tranny crossmember notched. I'm not really sure why....
2004 Overland WJ 4.7ho/545rfe/247/d44a
04ovrland is offline
post #62 of 504 Old 07-06-2012, 11:21 AM
narnwv
narnwv's Avatar
what do you mean?
~Aaron
narnwv is offline
post #63 of 504 Old 07-06-2012, 11:27 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Originally Posted by narnwv View Post
what do you mean?
Doesn't make any sense to me either. If this were true for every Jeep, RC would have had to "notch" the cross member when test fitting it on their own rig. Had they done that, and needed to do that on their ZJ rig as well, they would have incorporated this "notch" into the design. Is it possibly the difference between the 42re mount and the 545rfe? I didn't think the mounts were any different, but who knows?
~James
ezflip is offline
post #64 of 504 Old 07-06-2012, 11:40 PM
crazyinjun
How thick is the track bar. wondering if i should call and cancel track bar and order the JKS.
crazyinjun is offline
post #65 of 504 Old 07-07-2012, 10:26 AM
tsneath
Well got it pretty much done last night back went smooth no problems. I've got a little drive shaft vibration I think coming from the front. It look like I need to lengthen top arms a little. Rides great going to try to get some miles in it this weekend and go back over everything.
image-2207607546.jpg   image-926598746.jpg   image-115589622.jpg   image-3505606188.jpg   image-3507165166.jpg
tsneath is offline
post #66 of 504 Old 07-07-2012, 10:31 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Looks good!!! Is that last pic the notch on the cross member you were talking about? The vibe is hopefully just a pinion/caster angle issue. Get an alignment done and see where theyre at.
Let us know what you think after you get a few miles on her!
~James
ezflip is offline
post #67 of 504 Old 07-07-2012, 10:36 AM
adavis39
not to bad...need to disco that front sway bar and really see what kinda flex its got. what size tires you running?
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #68 of 504 Old 07-07-2012, 10:43 AM
tsneath
Ya that's the notch 31x10.5 tire 1.5 wheel spacer
tsneath is offline
post #69 of 504 Old 07-07-2012, 11:56 AM
oaklyjeep10
So the adj front control arms can fix the front drive shaft vibration?
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq
oaklyjeep10 is offline
post #70 of 504 Old 07-07-2012, 12:03 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Yes. They control caster and pinion angles.
Sent from my Commodore 64 using JeepForum
~James
ezflip is offline
post #71 of 504 Old 07-07-2012, 01:19 PM
PhantomWJ
2003 WJ
Can you take better pictures of the rear arms and mounting points.
PhantomWJ is offline
post #72 of 504 Old 07-07-2012, 08:00 PM
03wjay
2003 WJ
great looking jeep!
03wjay is offline
post #73 of 504 Old 07-07-2012, 08:09 PM
tsneath
Here ya go
tsneath is offline
post #74 of 504 Old 07-07-2012, 08:57 PM
04ovrland
i know the problem with the ZJ was that when they built their original prototype kit they did not have access to a V8 to test fit the kit on. so the production kit was produced without the notch that the v8's needed.
Problem the same deal on the WJ. because its not the mounts that are different it is the length of everything combined that causes even the slightest issues, such as the needed notching.
Back on topic though, if this kit turns out to be halfway decent ill have one sitting on my doorstep. especially if this death wobble doesn't go away!
post #75 of 504 Old 07-07-2012, 08:57 PM
Sohcvtec1995
Looks great, can't wait to do mine. Hopefully it works on 6 inches.
Sohcvtec1995 is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
