Guinea pig new RC Long Arm kit? - Page 30 - JeepForum.com
post #436 of 504 Old 05-08-2013, 07:46 AM
PhantomWJ
2003 WJ
Originally Posted by texlurch View Post
Yes and no;
It is an a-arm, but has a different bracket on the rearend and a flex joint there the same as the lower arms.
Rear mount point is raised about an inch over stock.
Front mounts are same style as stock.
Right...ok so very similar to the IRO a-arm?
PhantomWJ is offline
post #437 of 504 Old 05-08-2013, 08:38 AM
texlurch
yes
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is online now
post #438 of 504 Old 05-08-2013, 01:14 PM
berndog67
2003 WJ
so much for getting the long arm kit on completely, got the last box today and missing the front upper pieces and that x-flex spanner tool, almost cut the mounts off to be ready for them when they were supposed to be here today, anyone else have anything missing yet or is this just my luck again?
2003 WJ Overland, 4.7HO, D30 & D44A (1 tons going in now!), RC Long Arm, lifted 4" Front 6" Rear, RC 2.2 4" Shocks, JKS track bar, custom hi-steer, 35" Procomp M/T's on JK rims, beefed up Overland rock rails, custom skids and dif gaurds, Rugged Ridge 8500 synthetic winch in custom hidden mount
berndog67 is offline
post #439 of 504 Old 05-08-2013, 04:24 PM
Gunnison
Gunnison's Avatar
2008 WK
Regarding rear driveline vibrations after lift installed. I have moderate DS vibs over about 45mph both accelerating and decelerating.. I set the adjustable arms to the lengths RC suggested at tri link at 7 3/8 and lower arms at 34.5". with an angle finder on the underside of the diff closest to the yoke I show about 12-14degrees. Ok, for those of you that have the 247 (all time) T-case with the stock slip yoke and drive line.........were you able to dial out all of the driveline vibrations, and if so what arm measurements or angle worked for you? I am not looking forward to spending a day of trial and error in adjusting and test driving so I am hoping to shortening curve!
02 GC Overland, 4" RCLA, 4.5 Clayton Springs w 3/4spacers in front, Bilstiens, JKS Tracbar, Addco rear sway bar, Proto Fab Hi Clearance bumper, Smitty built 8,000 w/Syn
Previous Jeeps: 57 Willys, 74 J-10, 76 J-20, 80 CJ7, 91 XJ, 97 ZJ, 97 TJ, 00 TJ, 06 LJ Rubicon, 2010 JK Rubicon 4dr.
Gunnison is offline
post #440 of 504 Old 05-08-2013, 05:29 PM
berndog67
2003 WJ
measured mine before i started putting on the long arm kit, front was 6 degrees and the rear was 13, i know there not ideal, but thats what 4 inches on stock arms will get u, and i have no vibrations at any speed, so im hoping to have none after i finish the long arm, but we'll see
oh and if u guys have any problems, rough country is awesome to deal with, there over-nighting the things im missing, so im hoping to get it all done tomorrow after all!!
post #441 of 504 Old 05-08-2013, 11:33 PM
texlurch
Pinion should be at same angle as driveshaft, assuming you have the double cardan on the trans.
post #442 of 504 Old 05-09-2013, 07:10 AM
SKI_VT
To anyone who had the Kit installed by a hop,
How much did you guys pay??
"You people make it sound like Claytons are made from gold and unicorn bones while everyone else uses PVC and spaghetti noodles."
"The Great Turtle Race! -> Iceland vs. Bushwhacker! -> Place your bets!"
SKI_VT is offline
post #443 of 504 Old 05-09-2013, 07:15 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Plan on at least 8-10 hours of labor, probably more. At an average of $65/hr, you're looking at least $500-650.
~James
ezflip is offline
post #444 of 504 Old 05-09-2013, 09:47 AM
aleet25
2003 WJ
I had two shops in GA quote me $1000 to install because of all the extra work( cutting off OEM mounts, etc.).
aleet25 is offline
post #445 of 504 Old 05-09-2013, 09:11 PM
00grandbrick
Thats the same quotes I got. My advise pay the money and make sure to pay attention to the alignment when they are done.
00grandbrick is offline
post #446 of 504 Old 05-09-2013, 09:29 PM
aestrad1
if you were closer id install this for a 30 pack! well maybe not, but id be willing to help
aestrad1 is offline
post #447 of 504 Old 05-17-2013, 12:32 PM
berndog67
2003 WJ
buttoning up the back half today and let me tell u guys a huge tip for the flag nuts, do not use needle nose pliers, use small visegrips, that way u cant drop them and can pull towards u to make getting the bolts started easier, also when the rear half, do the top links first, and the bottom links last, and do the axle side of the bottom links first then the bracket end last, because its much easier to move the flex joints to get the bolts through then the press fit bushings on the axle side
also for everyone who is worried or hesitate on the quality or strength of the RC long arm, dont worry its comparable to IRO, in fact its nearly identical in most ways, course the Clayton one is stronger, but only due to the square links, and welding of the brackets, but if u bend the iro or rc links then your def wheeling alot harder then most of us who wheel a couple times a month
going out for a long two days of wheeling tomorrow and sun, so ill post up if i get any problems, but i dont foresee any clearance or flexing problems, did the cutting of the front end last week, and out back i only needed to roll the inside edge of the fender up and cut the bumper a half inch, now im running no bumpstop extensions in the rear and 3 inch bumpstop extensions up front til i flex it out and make sure i can take them out without tearing anything up, pretty sure i can get the 32's fulled stuffed, but want to make sure im not cutting them on anything up front, out back they clear everything perfectly
post #448 of 504 Old 05-19-2013, 02:52 AM
texlurch
Dumb question maybe, but why are you posting in the RC LA thread about your IRO 3 in lift?
And if you plan to drive that over bumps or turn the wheel much, you'll be trimming quite a bit off both ends of both wheelwells.
post #449 of 504 Old 05-19-2013, 06:36 AM
alfaitalia
Originally Posted by 1BADCJ8 View Post
Got most stuff done... I will for sure have to trim some but only in the front rear and the rear front... And of course I'll will have to trim the new bumper cover when I put it on... I also have to put the rest of the front back together with a new Radiator, A/C Condenser, Trans Cooler, Header Panel and Grill...
Wow it looks great but I hope the roads are smooth and straight where you live or your metal grinder is going to be put to a lot of use on those front and rear fenders...up to the flair line at least I would guess.
Wish it was legal to have the tyres stick out from the arches that far where I live.....looks great but would get me pulled in the first day in the NAZI state I live in!
BTW we have the best colour!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #450 of 504 Old 05-19-2013, 12:24 PM
1BADCJ8
Junior Member
1BADCJ8's Avatar
1982 CJ8
I'm sowy did I hurt your feelers for posting here? Because I wanted to...
Yeah as I said in my post I will be trimming for sure which is no big deal to me, I don't care much about that... Its not done just posted a few picks. Any way, I will do the trimming as needed for sure. As for them sticking out there isn't any problem with that here, It would be a bummer to live somewhere that doesn't allow it, I agree with that all the way...
Danno -
'82 Scrambler, 360-727, 60&14B, 4 Link Rear, 40's & some other stuff...
1BADCJ8 is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
