Guinea pig new RC Long Arm kit? - Page 26 - JeepForum.com
post #376 of 504 Old 04-02-2013, 10:48 PM
MWyatt
Did you have to lower the transfercase skid at all with that 1/4" drop?
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline
post #377 of 504 Old 04-03-2013, 01:53 AM
CruizinKev
texlurch, your Jeep looks awesome! btw I see there's a Monte Carlo sitting next to the Jeep in the garage?!
- Kevin -
2000 Jeep Grand Cherokee 4.7 Dailydriver
1979 Chevrolet Monte Carlo LS3 6.2 T56 Full Resto Project
CruizinKev is offline
post #378 of 504 Old 04-03-2013, 08:40 AM
texlurch
Nope, just had to get it positioned just right. 1/2 inch at closest point to the 242.
Yup, 85 SS with an LT4/T56 and Hotchkiss suspension
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #379 of 504 Old 04-03-2013, 12:05 PM
CruizinKev
NICE!! I'm building a 79 Monte pro-tourer with a LS1 & T56
- Kevin -
post #380 of 504 Old 04-03-2013, 12:18 PM
adavis39
texlurch, why does it look so low in the front? i mean it looks REALLY low compared to the rear
edit: maybe its just me? it looks ok from the drivers side shot, but from the pass side shot, it looks super low. maybe just the angle?
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #381 of 504 Old 04-03-2013, 03:24 PM
texlurch
Pass side rear was in a bit of a hole.
In the shop all 4 corners are even. Rear sits an inch higher, just like stock.
Net lift is 5 inches from the Upcountry height.
I guess when they advertise lift, it's from the stock, non-Upcountry numbers.
Thinking about adding some 3/4 spacers on the front, just to level it out.
Took a drive with the new front Addco bar; much mo' butta!!
texlurch is offline
post #382 of 504 Old 04-03-2013, 04:17 PM
Roger005
Lift is done: still have to swap front swaybar, and do some fine tuning. Drives good on the initial road test
Front hub to fender 24", rear 25.5". Guess the winch is sagging it a tad, and only have 1/2 tank.
Lift specs: RC long arms; IRO 6.5 springs, crossmember, xfer skid, rear sway bar links; Bilstein shocks; Level 8 16 x 8.5 wheels, Duratrac 265/75
Drag link flip, IRO TB drop bracket, RC TB
Still have to do the tie rod flip, inner sleeves, RCV axles, inner C gussets, Eaton E-locker
What kind of front push bar is that? I like that setup.
Roger005 is offline
post #383 of 504 Old 04-03-2013, 04:57 PM
texlurch
It's a combination bullbar, Fawkes relocation bracket and some home grown mods to get it high enough to clear the winch hawse.
No idea on the brand; I got it used.
texlurch is offline
post #384 of 504 Old 04-03-2013, 06:04 PM
Fawkes
I heart your dub, Tex.
Fawkes is offline
post #385 of 504 Old 04-03-2013, 06:15 PM
Jaketit
Wow really? That front sway bar is much better huh? I got the addco swaybar and it definitely helped over the stock coat hanger but the stick front looks pretty beef. Does it really help more?
Jaketit is offline
post #386 of 504 Old 04-03-2013, 10:04 PM
texlurch
Stock front looks large, but is hollow. Just the difference in weight is pretty significant.
texlurch is offline
post #387 of 504 Old 04-03-2013, 10:17 PM
PhantomWJ
2003 WJ
You are at 6" up fromt and almost 7" in rear...
PhantomWJ is offline
post #388 of 504 Old 04-04-2013, 08:54 AM
texlurch
From non-Upcountry numbers.
After a couple drives, the rear has come down a tad more. Now at 6.5 from stock almost exactly
texlurch is offline
post #389 of 504 Old 04-05-2013, 10:36 PM
texlurch
Got my Tom Woods shaft in, took it for a longer drive up and down the pass. Cruising at 65-70 handles the curves great.
Got my front flares done; once I get the rears on, and the RCV/ball joints done I'll go try and see how it flexs's.
Also got shipping notice on my JCR sliders so should be done for this go-round next week... yeah!
texlurch is offline
post #390 of 504 Old 04-06-2013, 07:49 AM
Gunnison
Gunnison's Avatar
2008 WK
Came home from my business trip and found 4 boxes from Rough Country so the LA upgrade kit arrived. Waiting for the Clayton springs, Bilsein shocks, isolators and JKS trac bar.
Still need to purchase SS and spring spacers to accommodate the 200lb winch and bumper.
02 GC Overland, 4" RCLA, 4.5 Clayton Springs w 3/4spacers in front, Bilstiens, JKS Tracbar, Addco rear sway bar, Proto Fab Hi Clearance bumper, Smitty built 8,000 w/Syn
Previous Jeeps: 57 Willys, 74 J-10, 76 J-20, 80 CJ7, 91 XJ, 97 ZJ, 97 TJ, 00 TJ, 06 LJ Rubicon, 2010 JK Rubicon 4dr.
Gunnison is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
